idle problems on 380 sec - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 05-18-2004, 04:27 PM Thread Starter
Date registered: May 2004
Vehicle: 1982 380 sec
i'm experiencing either too low rpms (less than 500) or too high rpms( around 2000) when idling.i couldn't figure a pattern yet (cold ,hot engine,humid weather).they drive me crazy .anybody else experiencing the same with an 82 380sec.thank you!!
adixxl is offline
post #2 of 8 (permalink) Old 05-18-2004, 06:24 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
RE: idle problems on 380 sec
Yes, this seems to be an all too common problem…
It’s driving your crazy???
All these high idle posts are driving me crazy!!![:p]
Here’s the newest thread…
http://www.benzworld.org/forums/forums/thread-view.asp?tid=1174513&posts=11&fid=12
jdc1244 is offline
post #3 of 8 (permalink) Old 05-18-2004, 06:35 PM
jdc1244's Avatar
Sorry if I sounded rude on that last post, we need some kind of w126 high idle problem forum where we just talk about that…[xx(]
Review the list and eliminate each possible problem. Item 1. (one) is the most common problem to the least occurring problem.
jdc1244 is offline
post #4 of 8 (permalink) Old 05-18-2004, 09:35 PM Thread Starter
thanks jdc1244
i was so new to this forum i had no idea this was a common problem
adrian
1982 mercedes 380sec
1997 volvo 850T5
2002 bmw f650 gs dakar
adixxl is offline
post #5 of 8 (permalink) Old 08-12-2004, 01:58 AM
Date registered: Aug 2004
yea ive had the problem for a while. you would think there would be a pattern but it usually happened at the randomest times. the trick is when its "idleing" or reving you have to put it into park at like a stop light and just rev it as hard as you can for a few times and put it back into drive. that usually works for me. you could probably get it fixed but its always too expensive. this is something that you just gotta live with
rabitsjag is offline
post #6 of 8 (permalink) Old 12-31-2006, 01:31 PM
Date registered: Dec 2006
I have a similar problem with my 1980 280SE (gray market) car. It idles high (2K RPM) in winter and lower in teh summer; when A/C is turned on, idles even lower at the point where engine stalls. It is burning so rich, and exhaust fumes enter car when is not in motion. I appreciate any recomendations.
Bruce A. Orford is offline
post #7 of 8 (permalink) Old 12-31-2006, 09:12 PM
jdc1244's Avatar
Here’s the list if things to look for first for high idle, common to all CIS cars:
1. Idle control valve
2. Idle control unit
3. OVP relay
4. Throttle position switch
5. Worn injectors
6. Broken/brittle/missing/disconnected vacuum hose(s)
I’m not sure of the location of the ICV or number 4 on the M110 but number 2 should be under the dash driver’s side and three is in the fuse box.
jdc1244 is offline
post #8 of 8 (permalink) Old 01-01-2007, 01:35 AM
talbir's Avatar
Date registered: Dec 2004
Quoted: 2 Post(s)
I would add to the list :
- worn injector seals
- worn inlet manifold seals
- incorrect air metering plate adjustment
talbir
Mercedes w124 500E 1993 Black 040
Mercedes w124 500E 1993 Spruce Green
Mercedes AMG 560SEC 1988
Mercedes AMG DOHC M117 w126 AMG Widebody SEC 1985
Mercedes 560SE Carat Duchatelet 1987
Mercedes w126 SEL Brabus
Mercedes w124 T Brabus
Porsche 911 Turbo SE Slantnose 1986
Mercedes 560E - w124 5.6 DOHC 360bhp by Stratton
Ferrari 328 GTS Quattrovalvole 1986 Koenig Widebody
Porsche 928 S4 by Strosek, Supercharged 550bhp
Mercedes 190E AMG Widebody
Mercedes SEC by Gemballa 6.9
talbir is offline
