Old 05-17-2004, 10:52 AM   #1 (permalink)
Prochambers's Avatar
Date registered: Jan 2004
Vehicle: 1987 420 SEL
Front Brake Pads
I know I need to change my front brake pads. Is there any special tool that i'll need to do them. Does the caliper have to be pushed back and if so, what is the best way to do it. [;)]
Prochambers is offline   Reply With Quote
Old 05-17-2004, 10:49 PM   #2 (permalink)
vwbuge's Avatar
Vehicle: 1985 300SD
RE: Front Brake Pads
I think it is a 19mm. A small punch. A 6" C clamp. Needle nose pliers. Once I pull the small cotter pins for the slide pins, I use the punch to pop out the slide pins. The pads will come out now. Remove the caliper and push pistons back in with c clamp. Use one of the old pads and flip it over as a flat surface on the piston. This operation is possible without removing caliper.
vwbuge is offline   Reply With Quote
Old 05-18-2004, 05:47 AM   #3 (permalink)
Thanks. I'm going to go at them in the next couple of days.[8D]
