Old 05-14-2004, 07:09 AM   #1 (permalink)
AAA of NY's Avatar
Date registered: May 2004
Send a message via MSN to AAA of NY Send a message via Yahoo to AAA of NY
ATF leak on 86 420SEL..and "STOP LEAK ATF" ? Help pls.
My 1986 420SEL recently progressed from having a minor ATF leak (Red clean oil) from having a less than minor leak in the same area. I used to get maybe a drip or two per week onto the garage floor, and now I get maybe half a dozen drips ESPECIALLY, when pulling out my driveway...I would presume even when the car is running too! I added ATF last week and I think I lost quite a few.
The car is running fine but I dont know if I have to have the transmission serviced ASAP or just leave it for now.
ALSO, Does anyone tried those "STOP LEAK ATF" ? Will you suggest using those chemicals on my transmission?
I appreciate your help on this matter. Thanks...
AAA of NY is offline   Reply With Quote
Old 05-14-2004, 07:24 AM   #2 (permalink)
Date registered: Mar 2003
Vehicle: 1991 560 SEL
RE: ATF leak on 86 420SEL..and "STOP LEAK ATF" ? Help pls.
Stop leaks didn't work on mine. I changed the pan gasket, and later the pan. REplaced O rings. Still leaks. I park on a piece of cardboard. It leaks more when it is full. It gets low, and slows down.
GreenGiant is offline   Reply With Quote
Old 05-14-2004, 07:30 AM   #3 (permalink)
AAA of NY's Avatar
That's what happened to mine ! I think it drips more when I added the ATF to the proper limits...
Old 05-14-2004, 09:08 AM   #4 (permalink)
Date registered: Mar 2004
Vehicle: 1984 500 SEL
I wouldn't suggest using any sort of "Stop Leak" additive. A few years ago I was rebuilding a transmission that wouldn't shift between second and third. Apparently the tranmission had been leaking, but working fine, and then some sort of "Stop Leak" was added. When I opened up the valve body, there was a green, congealed sludge that was holding a spring-mounted plunger from closing. That particular passage controlled the 2-3 shift and the green stuff was the "stop leak". During the rebuild, I found a worn rear seal was causing the leak ($5 part).
The lesson learned---if the transmission is working okay, but leaking, fix the leak. There really aren't too many ways the fluid can get out. It can come from around the dip-stick tube, the front seal, around the modulator, the pan gasket, or rear seal. Clean the bottom of the car, wipe away any oil, and puff some baby powder on the bottom parts of the tranmission. The source of the leak should show up pretty quick.
Good Luck
1984_500sel is offline   Reply With Quote
