Old 03-28-2004, 01:13 PM   #1 (permalink)
Geeky1's Avatar
Date registered: May 2003
Vehicle: 1986 560SEL, 1973 Buick Riviera
Send a message via AIM to Geeky1
HELP!!! I lost my service manual and I need a diagram so I can finish my oil change!!
I lost the service manual CD for my 560SEL (it's somewhere in my room, but that's as good as lost, with the state my room is in), and I'm doing an oil change on the car. The oil filter has like 3 or 4 copper washers, and I have no idea where the hell they go. I need the diagram in the service manual telling me where they go...
Can someone please e-mail it to me or post it or something?
Anonymous Post on Carsurvey.org about the 560SEL: "It's the only car I've owned that I insisted on hand washing myself so I could admire its details and check out the condition, touching up occasionally where necessary. I miss it very much. I often used to sit in the garage and look at it. Wife and daughters thought I was mad."
Geeky1 is offline   Reply With Quote
Old 03-28-2004, 02:20 PM   #2 (permalink)
Date registered: Jul 2003
Vehicle: 1989 560 SEC
RE: HELP!!! I lost my service manual and I need a diagram so I can finish my oil change!!
small copper is for the drain plug. small zinc one is for the top of the oil filter container. larger copper o-ring - not sure. but didn't use it and didnt seem to matter. large rubber o-ring for the inside of the oil filter cannister top. r&r.
1989 Mercedes Benz 560 SEC 196k mi.
cdeeznuts is offline   Reply With Quote
Old 03-28-2004, 02:23 PM   #3 (permalink)
Geeky1's Avatar
hmm. So the drain plug washer comes with the oil filter? Makes sense, now that I think about it... Which means that I now have to crawl back under the car and replace the stupid thing. Thanks.
Old 03-28-2004, 06:01 PM   #4 (permalink)
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
The copper and zinc washers are to protect the aluminum engines, so they’re important. The large copper washer is not used in the m117.xxx engines. [:)]
1991 300 SE (w126.024/M103.981) 140,000 miles
jdc1244 is offline   Reply With Quote
Old 03-28-2004, 06:50 PM   #5 (permalink)
Geeky1's Avatar
Protect them from what? Galvanic corrosion? By the way, I put it together as per cdeez's instructions and it apparently worked, since I took it out and drove it around for about an hour after that and nothing broke... [:D]
Old 03-28-2004, 08:20 PM   #6 (permalink)
jdc1244's Avatar
Geeky1 - 3/28/2004 8:50 PM
No – the aluminum alloy used to make the engine is relatively “soft� compared to iron, for example. The washers provide a flat surface to evenly distribute the torque load when the plug and filter bolt are tightened. Alloy on alloy contact can cause over time warping or distortions of the metal, which may lead to leaks or otherwise damage the contact area.
Does that mean your engine will get damaged if you don’t use the washers? Of course not…
…but one must remember who designed and built the engines – have you ever known a German to throw caution to the wind and not play it safe? (rhetorical question.)[;)]
In any event I’m glad you’ve got the crisis dealt with and new oil in the engine.[:)]
