» Site Navigation
» Other Sites
Old 02-18-2004, 06:39 PM   #1 (permalink)
Date registered: Feb 2004
Which glue to use on wood dash trim?
The wood dash trim on this one is loose in sections and needs to be reglued. Which glue works best on that? Thanks.
1984 300SD--298,000
RockinWagin is offline   Reply With Quote
Old 02-18-2004, 06:47 PM   #2 (permalink)
DDEWSBURY's Avatar
Date registered: Jan 2004
Vehicle: 420SEL, 560SL
Send a message via MSN to DDEWSBURY
RE: Which glue to use on wood dash trim?
If it's the veneer peeling up, I suggest expoxy. If it's the whole piece of wood, check the plastic behind the wood that has the connectors. Shouldn't need glue then.
I used a heat gun and peeled the old varnish right off, and then just laquered the veneer clear for a lighter color.
Duane
DDEWSBURY is offline   Reply With Quote
