Old 02-14-2004, 10:13 PM   #1 (permalink)
DDEWSBURY's Avatar
Date registered: Jan 2004
Vehicle: 420SEL, 560SL
Send a message via MSN to DDEWSBURY
Please, need some help removing wood trim
Can anyone explain the best and quickest way to remove the following wood trim 1990 420 SEL?:
Climate Control Piece
Long horizontal dash board pieces
Door Pieces
I have removed the piece by the shifter and the piece on the ashtray and refinished them natural, and I am very pleased. However, I need to know how to get the other pieces off.
A note that may be helpful to others, is that I used a heat gun and razor scraper and the old cracked varnish came right off, leaving the nice veneer wood grain. Careful scraping though, use enough heat to soften (so you don't gouge), but not so much that you burn your wood.
Look forward to any responses.
DDEWSBURY is offline   Reply With Quote
Old 02-15-2004, 01:40 AM   #2 (permalink)
Date registered: Jul 2003
Vehicle: 1989 560 SEC
RE: Please, need some help removing wood trim
to get the center a/c panel one: need to : remove the ashtray, then the radio. Above the top of where the radio was you will find two screws. remove and then you gotta shimmy that wood piece a little bit down to get the top of it to get under the dashand voila it'll come out.
1989 Mercedes Benz 560 SEC 196k mi.
cdeeznuts is offline   Reply With Quote
Old 02-17-2004, 07:11 AM   #3 (permalink)
DDEWSBURY's Avatar
Center dash completed, thanks. Just need advice on removing the other pieces now.
Duane
Old 02-17-2004, 03:01 PM   #4 (permalink)
Panazonic's Avatar
Vehicle: MB w126 280S
Send a message via MSN to Panazonic
(what is the price for the new wood parts?)
Panazonic is offline   Reply With Quote
Old 02-18-2004, 07:16 AM   #5 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
You don't want to know! THe 3 dash trim parts (no HAAC or trans shift surr.) is 700+ dollars..
Google Heritage Wood Works, that guy does Amazing work for reasonable amounts of $$!
I think his name is Drew..
Jonathan
Blue Ridge Mercedes/AMG East (temp down!)
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
89 190E 2.6 5sp
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
86 560SEL AMG 6.0L 32V
jhodg5ck is offline   Reply With Quote
Old 02-18-2004, 08:18 AM   #6 (permalink)
big dan's Avatar
Date registered: Oct 2003
Vehicle: 1985 500SEC Conv.
Those pieces of dash trim are a b*tch to get off.
I wouldn't even try it. That veneer is bonded to an aluminum backing with studs attached. You need to go under the dash and remove the nuts from the studs. problem is, EVERYTHING is in the way: wiring, vents, structure etc.
Friend of mine is a Benz dealer tech, he told me the guys in the shop hate doing that job. All that work for a couple of pieces of trim...
The door pieces are do-able. The door panels must come off, then you can get to the back of the trim and remove the clips.
Regards,
Dan C.
1975 450SL (sold)
1986 560SEL (sold)
1993 300SE (sold)
2002 C230 Coupe
1985 500SEC Convertible
big dan is offline   Reply With Quote
