» Site Navigation
» Other Sites
Old 01-22-2004, 02:26 PM   #1 (permalink)
Date registered: Jan 2004
Vehicle: 1990 560 sel
fuel smell in cabin
I have a 1990 Mercedes Benz 560 sel. The car runs perfect, with one exception. There is an odour of fuel which enters into the cabin when driving. When ever I leave the car parked in the enclosed garage, the garage area smells like fuel aswell. Any suggestions? Thank you in advance for your expertise on this matter.
amazingnight is offline   Reply With Quote
Old 01-22-2004, 02:27 PM   #2 (permalink)
bronze560SEL's Avatar
Vehicle: 03' C320 4Matic SS
Send a message via AIM to bronze560SEL
RE: fuel smell in cabin
i'm not sure but is there a leak or some sort in the exhaust lettin fumes in the car?
-Sheldon.
2003 C320 4Matic SS Black/Black
20% Black Tints
Clear Corner
Eclipse AVN 5435 DVD/NAVI/SIRIUS/MP3/IPOD
1 JL 10" W6 V2 w/ sealed box
1 Alpine V12 MRD-M1005 1000w Mono Amp
1 Alpine PDX-1.1000 Mono Amp for Bose Speakers
Sirius Radio
Eurolite H7 High and Low Beam
Piaa Signals
Piaa Fogs Xtreme White Plus 4000K
Much more to come...
bronze560SEL is offline   Reply With Quote
Old 01-22-2004, 02:39 PM   #3 (permalink)
dpalmer's Avatar
Date registered: Oct 2002
Vehicle: 1984 500 SEC
Open the fuel door, there should be a hole just below the filler tube, take a coat hanger or something long and thin and push it through this opening. That hole is the overflow tube that runs down towards the passenger rear wheel. I had the same thing happen to me and then I noticed a fuel puddle around the filler cap. Once I cleared the overflow tube the smell was gone in about 30 mins.
Hope this helps. [8D]
D.A. Palmer
BigBen 84 500SEC
http://www.cardomain.com/id/bigben500
Clear Front Corners, Clear Taillights, White Instrument Gauges w/Blue Illumination,Sunroof Deflector
Stainless Steel Magnaflow Resonator (Mid Muffler)
Stainless Steel Magnaflow Muffler w/ Chrome Tip
dpalmer is offline   Reply With Quote
Old 01-22-2004, 07:29 PM   #4 (permalink)
Panazonic's Avatar
Vehicle: MB w126 280S
Send a message via MSN to Panazonic
dpalmer - 1/23/2004 11:39 PM
Hehe. a friend of mine who has a w123 230E had a fuel leak trough the owerflow tube. It fell off, and the fuel leaked into the trunk under the carpet.
So we mounted a new hose, and screwed out the carpet in the trunk. Then we flushed the trunk (the trunk on a w123 (don't know if the w126 has it) has 2 draining holes in the trunk) with water. And the smell was gone [:)]
Panazonic is offline   Reply With Quote
Old 01-22-2004, 07:36 PM   #5 (permalink)
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
Check the pressure reg at the rear of the fuel distributor. Sounds like its leaking...
BENZDOC is offline   Reply With Quote
Old 01-22-2004, 11:07 PM   #6 (permalink)
Thank you all for your helpful suggestions. Benzdoc, you hit the nail right on the head. I just got my car back from the mercedes benz dealer here in Vancouver, B.C., and sure enough the "EGA" valve was leaking.
