Old 01-22-2004, 10:38 AM   #1 (permalink)
Date registered: Mar 2003
Vehicle: 1991 560 SEL
rear wheel bearing
The car started making a scary noise from the right rear, and after jacking it up ,I found that the wheel bearings are bad. Anyone ever changed these before? I finally got the half shaft off, but am puzzled by the best procedure as to the removal of the weird grooved nut that retains the hub assembly. Any ideas?
GreenGiant is offline   Reply With Quote
Old 01-23-2004, 09:05 AM   #2 (permalink)
RE: rear wheel bearing
Just a follow up. I did get the thing disassembled. It was full of rust and dirt. I had never cleaned and repacked the rear wheel bearings, nor has anyone else I talked to. Might be a good idea, especially if you, like me, live in an area (Houston) where you are driving on flooded roads. Water got past the seals, which are old and leaky. Half shaft rusted to the hub, bearings bad, and hub destroyed. Half shaft already had a bad boot, and a loose joint, so it was due for replacement anyway. $100 used at a salvage yard. Hub was $220. Car has been on jack stands since Monday, and I am stuck driving the wife's van. Maybe the rear bearings should be cleaned, repacked, and the seals replaced every 100,000 or so.
Old 01-23-2004, 02:14 PM   #3 (permalink)
BenzWorld W126 & W201 Host
spanners's Avatar
Date registered: Feb 2003
Vehicle: 1988 420SE, 2002 C180 Kompressor, 200 ML320
Send a message via MSN to spanners
Greengiant
How did you get the nut off?
Did you buy the special socket?
I always though the rear wheel bearings were sealed, is this not the case?
Work is the curse of the drinking class!
spanners is offline   Reply With Quote
Old 01-24-2004, 05:32 PM   #4 (permalink)
Bearings are sealed...at least they are supposed to be. My seals leaked, water and dirt got in, and the bearings ruined. I thought there would be some special tool for the slotted nut. The shop foreman at the Stealership told me to use a punch and hammer. That worked. Car is all back together now, and fine. Just wondering if anyone else has had this problem.
