Parking brake adjustment - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 01-05-2004, 07:59 PM Thread Starter
Date registered: May 2003
Vehicle: 1986 560SEL, 1973 Buick Riviera
Send a message via AIM to Geeky1
The parking brake pedal on my 560 is now getting to the point where it's rediculously stiff. It's been getting worse over the course of about a year, and it's now getting to the point where it's absurd.
It also doesn't disengage properly; the parking brake itself will disengage, but there's enough slack in the pedal that if I don't hold it up with my foot for a minute or two after I start driving, it'll fall down far enough to put the parking brake light on, which is really irritating...
So, how do I go about adjusting the parking brake?
Past:
1967 250SE Coupe | 1986 560SEL | 1987 560SEL | 1973 Buick Riviera
Current:
1975 350SE [grey market, stick shift] | 1987 300D Turbo | 2007 Subaru STI Limited
Geeky1 is offline
post #2 of 8 (permalink) Old 01-06-2004, 05:59 PM
420SEL Realtor's Avatar
Date registered: Feb 2003
Vehicle: 88 420 SEL
RE: Parking brake adjustment
Geeky1,
My parking break works - but has a difficult time releasing all the way back up. ie: the red light on the dash remains on until I play with pulling the pedal up with my left for for a while... I tell others not to use it at all.
My local indy MB shop told me when I bought the car to "live with the hassle," as it would be SEVERAL hours dismantling the entire dash, etc. to get at the cable to lube it.
'didn't answer your question exactly, but hope this helps?
'88 420 SEL Daily Driver
'83 240D (Manual) SOLD, but always remembered
'83 240D (Auto) SOLD (parts car)
420SEL Realtor is offline
post #3 of 8 (permalink) Old 01-06-2004, 06:03 PM Thread Starter
Oh fun. Sounds like it's time to tear into the dash* and see how it's done
*not on the car I drive, of course. This is what the parts car is for. [:D]
Past:
Current:
Geeky1 is offline
post #4 of 8 (permalink) Old 01-06-2004, 06:55 PM
Date registered: Jul 2003
Vehicle: 89 420 SEL (sold), 01ML320 (sold), 03 S430 4MATIC, 06 ML500
I might be way off to lunch on this one, but how about checking the return srings on the rear brakes?
Big D is offline
post #5 of 8 (permalink) Old 01-06-2004, 07:09 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
Same problem here, not uncommon for cars of this vintage. I had the brake tightened/adjusted – it works great but there’s still a tiny amount of “play� allowing whatever makes the connection to the p brake dash light connect. First time it happened I thought I had a brake problem! It happens now very rarely but when it does I just pop it up with the top of my left shoe. Perhaps the electrical connection can be adjusted or replaced or disabled? Anyone? [?]
jdc1244 is offline
post #6 of 8 (permalink) Old 01-06-2004, 08:56 PM
Where's my auto-leveling?
AndyFracica's Avatar
Date registered: Sep 2003
Vehicle: '09 ML350, '03 E320, '99 E320 4Matic, '98 C280
jdc1244 - 1/6/2004 9:09 PM
I have an '87 300 SDL and the parking brake works like new. I have never done anything to it other than change the brake shoes when they fail.
You may want to see if you can spray something like WD40 or some other spray lubricant on to the cable. What might work better might be garage door Lube. I sprays on as a liquid and later turns to a gel like grease, if you can find it.
Andy
2009 ML350, Iridium Silver, Ash MB Tex
P2: Rear Cam, 115V Outlet, Parktronic, Pwr Seats w/ 4-Way Lumbar w/ Mem Pwr Folding Mirrors, Comand w/ Navi & Voice Control, HD Radio w/ Satellite, + iPod/MP3 Interface, Harman/Kardon, Keyless-Go, Pwr Liftgate
Lighting Pkg: Bi-Xenon Headlamps, LED Tail Lamps, Headlamp Washers
Extras: Hitch, Running Boards, Chrome Door Handle Inserts
Mods: Tinted front windows, Sports Pedals
AndyFracica is offline
post #7 of 8 (permalink) Old 01-08-2004, 10:14 PM
Vehicle: 88 420 SEL
...I like Big D's idea re: rear springs...
However, I think my case is more a matter of a weak parking break return spring than anything...
post #8 of 8 (permalink) Old 01-09-2004, 05:20 AM
Samurai1833's Avatar
Vehicle: 2006 E500, 2013 S550 and a retired 88 SDL
Two wire ties worked for me, I hooked one end around the brake pedal and the other on the little corner of trim that sticks out, just above the hood release.
Later when I went in for general repairs the mechanic fixed it without me even mentioning the problem.
"Your mother was a hamster and your father smelt of elderberries."
Samurai1833 is offline
