» Site Navigation
» Other Sites
Old 09-17-2003, 06:36 PM   #1 (permalink)
Gatsby1066's Avatar
Date registered: Aug 2003
Vehicle: 380SL,560SEL,S600
For all those with big rims and wide tyres, do your rims touch your tie rods in front? If ...
For all those with big rims and wide tyres, do your rims touch your tie rods in front? If so, is it when you drive over potholes?
240D, 380SL, 560SEL, S600, ML55
Gatsby1066 is offline   Reply With Quote
Old 09-17-2003, 08:05 PM   #2 (permalink)
SheepAlert's Avatar
Date registered: Dec 2002
Vehicle: 560SEC
Not here, I would consider that to be a major problem....
1989 560SEC
1987 560SEC
SheepAlert is offline   Reply With Quote
Old 09-18-2003, 12:52 AM   #3 (permalink)
Twizted's Avatar
Date registered: Jun 2003
Vehicle: '83 300 SD (turbo)
Mine don't rub at all. I got them from SheepAlert. When I put my 140 rims on, they A...
When I put my 140 rims on, they ALMOST rubbed the TRE, but never did.
However, I had to use spacers because they rubbed the calipers.
Aren't the stock rims a 14x7 22mm offest???
I know that stock tire size is 185/70/14...
'84 300SD w/MANUAL TRANSMISSION
Propane Injected
Air Intake tube w/cone filter
'83 300 SD (propane injected)
Matrix Intake
Modified Resonators
Modified Wastegate
Eibach Lowering Springs
Smoked Rear Lenses
Euro Headlights
JVC DVD/MP3/WMA deck
1 12" JL W7
Reverse Glow Gauges
Lorinser deep dish 16x8 chrome wheels
+ more...
- PHOTOS HERE
Twizted is offline   Reply With Quote
Old 09-18-2003, 01:08 AM   #4 (permalink)
85DRTYSTHBENZ's Avatar
Date registered: Feb 2003
Vehicle: 85 300 SD
i believe they are 14x6 or 6.5...
1985 300SD 160K MILES
QUANTUM TINTED WINDOWS
CLEAR FRONT SIGNALS
CLEAR TAIL LIGHTS
CHROME DOOR TRIM AND MIRROR COVERS
JVC KD-LH1000 CD PLAYER
ALPINE AND MB QUART 4X6
MTX THUNDER 6304 AMP
KICKER 15" SOLOBARIC L7
3.0 CU.FT. VENTED BOX
MTX THUNDER 81000D MONO AMP
LIGHTNING AUDIO DIGITAL 1 FARAD CAP.
ALL WIRING FROM KNUKONCEPTZ.COM
0 GAUGE KOMPRESSED KABLE POWER WIRE
10 GAUGE TWISTED KARMA KABLE SPEAKER WIRE
(18 INCH AMG MONOBLOCK AND NEW PAINT COMING SOON)
85DRTYSTHBENZ is offline   Reply With Quote
Old 09-18-2003, 08:59 AM   #5 (permalink)
Gatsby1066's Avatar
I am trying to put some 16inchers so I'll get a bit more tread and better handeling. The s...
I am trying to put some 16inchers so I'll get a bit more tread and better handeling. The size is 8X16 225/55-16 is that too big? Thank you for your help.
Old 09-18-2003, 09:02 AM   #6 (permalink)
Gatsby1066's Avatar
I bought them blindly not knowing from a 500SL. Any advice is appricieated. ...
Old 09-18-2003, 09:59 AM   #7 (permalink)
Twizted's Avatar
Those should be fine, but what's the offset??? I've been told that my Lorinsers are 1...
I've been told that my Lorinsers are 16x8 11mm offset.
Old 09-18-2003, 10:08 AM   #8 (permalink)
Gatsby1066's Avatar
How does one measure the offset?...
Old 09-18-2003, 10:46 AM   #9 (permalink)
Vehicle: Mercedes Benz 420SEL
Big rims and tires
Hi.
I have 18x8 and never had a problem with rubbing. I do use spacers, as our original offset is 25 mm and my wheels are 37 mm, but never had a problem with them, either.
I don't quite remember how to do it, but I know there is very detailed and technical explanation of offset measurements at the Tire Rack website.
On the tire size question for the 16", I believe 225/60/16 would be a more appropriate size, but that is just me.
regards,
Jose
JoseByron is offline   Reply With Quote
Old 09-18-2003, 06:33 PM   #10 (permalink)
Twizted's Avatar
Re: Big rims and tires
That's a much bigger diameter than the orig.
225/50/16 is pretty close to 185/70/14.
If you jump to a 60 profile, and raise the width, it increases the overall height quite a bit.
