Old 07-02-2003, 12:23 PM   #1 (permalink)
izzodesh's Avatar
Date registered: Jun 2003
Vehicle: ML55 AMG and 420SEL
What is normal engine temp? [:0]
[:0] ok guys..
my elec fans are workingover time...i knwo it s hot recently in NJ but dam the engine is runnin like 90 most the time....i dontthink its normal...
what are all your guys temps?
i am changin grill this weekend thou 8) new pics soon!
oh ya dont forget anyone in northeats we have a meet in NY!!!! come july 13th!
http://members.cardomain.com/izzodesh
-home of the 420 and ML55
we ride together we die together..
bad boys for life 8)
izzodesh is offline   Reply With Quote
Old 07-02-2003, 12:41 PM   #2 (permalink)
dtkw's Avatar
Vehicle: 86 560SEL
My 560's engine run around between the 80 line and the next most of the time. If I got st...
My 560's engine run around between the 80 line and the next most of the time. If I got stuck in traffic and it would go up alittle and then when I was moving and of course, the faster I went, the faster it cooled off. My guess it has a lot to depend on outside temp. Anyone?
dtkw is online now   Reply With Quote
Old 07-02-2003, 01:19 PM   #3 (permalink)
Vehicle: 83 500SEL
about the same here
When living in the Northern California bay area where average temps reached between mid60s to 70s, my needle sat about a mm above the 80 mark. a little more when idling at a stop light but down when in motion.
I am now in Los Angeles and the temps have been in the high 80s, low-mid 90s. My needle is usually right in between the 80 and first paint mark above that even when moving. It does reach the paint mark when standing sometimes. I've checked the coolant (it's about 6 months old), oil level, and thermostat seems to be working. Car runs ok.
I think it can feel more ennerving to see that needle move a lot because these cars seem to have a "real" temp gauge that shows you what's going on with the engine temps as opposed to modern cars that have a "simulated" temp gauge that actually have only 2 settings: "normal" and "it's too late you've overheated your engine already"
I think I'd worry if the needle stayed close or passed the paint mark above the 80 mark on a prolongued basis.
graymarket500SEL is offline   Reply With Quote
Old 07-02-2003, 05:27 PM   #4 (permalink)
SheepAlert's Avatar
Date registered: Dec 2002
Vehicle: 560SEC
Always 82....
Always 82.
1989 560SEC
1987 560SEC
SheepAlert is offline   Reply With Quote
Old 07-02-2003, 05:38 PM   #5 (permalink)
mcoleman's Avatar
Date registered: May 2003
Vehicle: 1987Mercedes 560 SEC
You may need a new thermostat. Is your coolamt mixture too strong on antifreeze? 50/50 wor...
You may need a new thermostat. Is your coolamt mixture too strong on antifreeze? 50/50 works best for freeze protection and engine cooling efficiency. High concentrations of antifreeze in the coolant does not cool as efficient as that with the proper mix. When was the last time your coolant was changed?
Mine runs right where it should (just below the 80 c mark)right about 75 C. It will climb to 90 C if I am driving it hard up some of the canyon roads on a very hot day (95 + F)with the A/C running.
mcoleman is offline   Reply With Quote
Old 07-02-2003, 06:29 PM   #6 (permalink)
seanrob's Avatar
Vehicle: 82 300 TD
Geezz.........
Man come on........you put in pimp daddy grille that cuts off all airflow and then wonder why your ride runs hot? How old are you dude?
seanrob is offline   Reply With Quote
Old 07-02-2003, 09:27 PM   #7 (permalink)
Vehicle: 1984 MB 500SEC
Re: Geezz.........
Agree with you.
Anyway mine is normally around 80C in normal driving and will easily go to a little over 100C in the hot traffic of Bangkok (over 100F temp and 5 miles/hour speed)
dispunt is offline   Reply With Quote
Old 07-04-2003, 07:46 AM   #8 (permalink)
izzodesh's Avatar
heheh mine is pimp daddy i got new grill but it aint any beta.... my temp only goes up ...
my temp only goes up for a bit to 90 and thats only on hot days when its liek 90 plus outside...
sean robe why u asking my age?
thanks everyone for the info
guess everything id ok for now...
Old 07-04-2003, 09:28 AM   #9 (permalink)
SheepAlert's Avatar
Vehicle: 560SEC
Izzo... let's see a pic of the pimp-daddy grill. [8D]...
Old 07-05-2003, 07:55 AM   #10 (permalink)
izzodesh's Avatar
aight here ya go fellow pimp masta: http://www.cardomain.com/id/izzodesh go thru all...
go thru all the pages u will likie 8)
the new grill i got is no different....so i have to figure out a way to have the plastic access pull thing away...
HELP!
