Old 07-17-2000, 03:21 AM   #1 (permalink)
Date registered: Dec 1998
No aircon, fan speeds, recirc working.
Hello all,<p>I have a cheapie 1988 560 SEL that I am in the process of sorting out. Most of the centre console is dead, there are no fan speeds, no aircon, and no air recirc.<br>Is this most likely down to the resistors on the heater motor? I would welcome any advice, certainly before winter :)<p>Regards<p>Chris
Old 07-21-2000, 10:58 AM   #2 (permalink)
Re: No aircon, fan speeds, recirc working.
the controls may be bad. I've heard that Mercedes had problems with their climate control units in the 80's. <p>I'm still trying to get mine to blow from the front vents and not the top. (the heat index is 110 in Dallas today)
Old 08-07-2000, 07:28 AM   #3 (permalink)
: the controls may be bad. I've heard that Mercedes had problems with their climate control units in the 80's. <p>I'm still trying to get mine to blow from the front vents and not the top. (the heat index is 110 in Dallas today)<p>Hmmmm, I think it maybe the ignition switch!
Old 08-23-2000, 11:14 AM   #4 (permalink)
There are several possible causes:<p>1) There is an under the hood fuse box that could<br>have a dead fuse.<p>2) There is a second "in-line" fuse behind the<br>panel for the blower motor.<p>3) The blower motor itself could be bad.<p>4) The console switch panel printed ciruit board <br>may be malfunctioning.<p>5) There is a blower circuit switch on the <br>ignition. Sometimes you can get the blower to<br>work by wiggling the key.<p>Good luck!<p>
Old 08-29-2000, 06:43 AM   #5 (permalink)
Thanks for the advice, the culprit was the ignition switch. Mind you it wasn't cheap to fix as the steering lock needed replacing too. I dont suppose you know where the fuses for the electric rear seat is? <p>
Old 01-14-2001, 12:47 PM   #6 (permalink)
humm...I have been suspecting the fuses or the<br>blower motor in 88 420SEL. Any way to check this out on the ignition? <p>My console has flakey problems,like the oil guage sometimes goes dead and a slight tap on the odometer reset button will cause the guage to come to life (not a oil sending unit problem). The other associated problem is the odemoeter reset button does not seem to work-(can't reset the odometer - wlll not push in to reset dial/mileage).<p>Thanks for any ideas on where to look.<p>Ed
