Old 02-08-2008, 04:53 PM   #1 (permalink)
jwc
Date registered: Feb 2008
fuel pump relay issue
I have a 86 mb 560 SEL that will start but dies instantly thereafter. If I hotwire the fuel pumps, the engine will run but at a high idle. I've checked all the wiring to the fuel pumps. I've replaced the fuel relay with a supposedly checked used one. Which pins on the relay do I jump to check it? Or is there something else I should check. Any advice? Thanks, JWC
jwc is offline   Reply With Quote
Old 02-08-2008, 05:36 PM   #2 (permalink)
livefreeordie's Avatar
Date registered: Oct 2007
Vehicle: 02 SLK230 Komp. 08 Honda CRV
welcome
you might want to post this question on the W126 board, you will get a much faster response. Good luck
livefreeordie is offline   Reply With Quote
Old 02-15-2008, 02:57 PM   #3 (permalink)
Date registered: Dec 2007
Thumbs up stalling 560 sel
Had similar problem with my 74 450 sl,don't know how close these are related,but if you can hear the pump run when you turn the key on,most likely it is either the cold start valve or thermo time switch, but I really don't know how close these to auto's compare.
rsanders is offline   Reply With Quote
Old 02-15-2008, 04:01 PM   #4 (permalink)
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6 (50k original miles)
Welcome jwc and rsanders, to take advantage of all the forum features, please re visit the 'Welcome to the Forum' tutorial sticky on top of the W126 page, as well as the two DIY stickies.
It will show how to search the forum, and even has a link to the Russian MB site where you can run a VIN#. The forum archive has a wealth of information write up's re your topic.
Good luck
Please complete your profile with a location and car mod (see sticky). It makes it easier for member to offer advice.
Teutone is online now   Reply With Quote
Old 02-16-2008, 01:02 PM   #5 (permalink)
Serintek's Avatar
Date registered: Aug 2007
Vehicle: Mercedes 1982 380 SL, 1988 560 SEL Navy Blue
Send a message via Skype™ to Serintek
Post
Got exactly the same problem 2 weeks ago. Here weather passed fromn -20 to 5 above, and with melting snow and rain, realy probably got some humidity in it. Original realy from 1988 560 SEL.
Next day took it off, got it inside for 4 hours, slammed it gently on the bumper twice and put it back in place. Everything worked well. Got the car back from work to home 50 miles, and then.... ordered a new one. The relay, I'll keep it for spare in case...
Good luck
Martin Richer
New Brunswick Canada
1982 380 SL Grey
2002 Mazda Tribute V6 4X4
1999 Yamaha Roadstar 1600 cc
Serintek is offline   Reply With Quote
Fuel Pump Relay? GDC W124 E,CE,D,TD Class 9 10-29-2007 08:38 AM
fuel pump relay tommy 12000 W210 E-Class 0 04-15-2007 12:51 AM
Need Fuel Pump Relay.... Oilguy W126 S,SE,SEC,SEL,SD,SDL Class 3 03-02-2006 06:00 AM
Fuel Pump Relay andreifs W124 E,CE,D,TD Class 10 02-28-2006 01:43 PM
85 380SE fuel pump relay issue ScottP General Mercedes-Benz 0 04-20-2004 09:31 AM
