Old 11-27-2007, 05:57 AM   #1 (permalink)
Date registered: Apr 2006
Vehicle: 1990 560 SEL, 1991 560 SEC Euro 75k
Interior upgrade..differance between MBTex and Leather
What is the differance between MBTex and leather? Did they use MBTex on seating or just trim parts like door panels, dash boards, etc.
I recently upgraded to leather (from velour) but noticed the bolsters have a white fabric backing...now I'm questioning if the seats are leather. The seats are wrapped very snuggly around the frames so it's almost impossible to see the underside. It looks like leather, but it just doesn't seem to have the tell-tale leather smell. The interior came from a car that was reupholstered and is in perfect condition.
Birmingham, MI
graftdesign is online now   Reply With Quote
Old 11-27-2007, 06:11 AM   #2 (permalink)
AxelWulff's Avatar
Date registered: Oct 2004
Vehicle: 1990 SEC
Very well made vinyl can be hard to distinguish from bad leather, but the original Roser leather MB used is very good quality and it is easy to tell the difference.
The leather does have the white cloth backing you found. This is mostly to help with the assembly process as it makes it much easier to pull the leather covers over the frame and springs.
The easiest place to look for the difference between leather and vinyl are the seat bottoms. The top is leather, but the sides are vinyl. On close inspection you'll notice some color and texture differences between the seating surface and the sides. This is what I found on my car, a 1990 SEC model. Your's may be different.
Regards,
Axel
1990 SEC, Arctic White w/gray interior, M119.960 326 Hp. engine from 1992 500 SL, 722.370 transmission from 500E (reinforced clutches), 2:82 Differential, Euro Headlamps, 1st Gear Start module, One-Touch Window module and Keyless Entry module all from BergWerks, Bilstein HD Shocks on front axle, H&R lowering springs front and rear, AMG 3-piece 17" rims, 8.5" in the front and 10" at the rear.
AxelWulff is offline   Reply With Quote
Old 11-27-2007, 07:28 AM   #3 (permalink)
Thanks Axel.
It's very easy for the mind to start playing tricks on you...expecially when its hard to tell the differance between good vinyl and bad leather as you eloquently point out.
I searched an earlier post that suggested that the underside should resemble suede...which is why I got off on a tangent. The white backing that helps in assembly totaly makes sense.
Old 11-27-2007, 01:43 PM   #4 (permalink)
Rmac58's Avatar
Date registered: Nov 2007
Vehicle: '83 300SD-daily driver '84 300CD-weekend car
Send a message via Yahoo to Rmac58
I can tell I have leather on the top of the back seat, as it has been the worse for wear sitting in the sun. When I get around to it, I'll replace with vinyl.
Don't know when MB started using leather just where you touch the seat, mostly.
'83 SD-daily driver
'84 CD-weekender!
Rmac58 is offline   Reply With Quote
Old 11-27-2007, 08:10 PM   #5 (permalink)
smack's Avatar
Date registered: Sep 2006
Vehicle: 1973 450SL 1991 420SEL 2008 Jeep Commander
Smell isn't a factor
The leather smell is added chemically to the leather...even on new cars. The aftermarket folks may well buy unsmelly leather. This little tidbit came from the guy who sells most of the leather to the big three so I hold some credence to it.
My Mercedes keep me so broke, I can't even pay attention!!
smack is offline   Reply With Quote
Old 11-27-2007, 08:19 PM   #6 (permalink)
Cirrus2's Avatar
Date registered: Oct 2006
Vehicle: 1985 380SE US Spec | 1983 500SEL EURO Spec | 1998 GMC Sierra 2500 6.5 Turbo Diesel
Send a message via AIM to Cirrus2
MB TEX is far more durable, I not long ago had my MB TEX seat patched with leather. Here is a picture maybe you can tell the difference. The leather is softer and feels moist-er than the MB TEX. The sides of horizontal part of the seat are now leather but the middle and backing is MB TEX. Hard to tell isn't it?
1985 380SE
Done:
Katmac Euros | Full Pioneer Speaker Upgrade | Alpine Sub/amp | Period correct Early AMG/ATS made 15" Pentas | GEN I AMG Steering Wheel | Full Front End rebuild | Seat repairs | Some New Zebrano Wood|
To Be Done:
Drivetrain Swap From A Gen I 83' 500SEL Euro With 231HP Engine And 2.24 LSD| Get The Rust Out!
|This Damn Thing Has Me Broke!|
Cirrus2 is offline   Reply With Quote
Old 11-27-2007, 08:48 PM   #7 (permalink)
mckellyb's Avatar
Date registered: Sep 2007
Vehicle: '89 420 SEL, 142K
Think of MB Tex as ultra-kick ass vinyl. I'm shocked at how un-vinyl like it is, but the stuff is nearly indestructible. My wife's '81 W123 had it, and even in the Texas sun & heat, the stuff looked nearly new after 15 years of two kids and abuse.
With the newest pseudo-leathers are actually pretty amazing. I'd pick them for feel/look over even moderately-good leather, in many cases. Given how real leather ages, I'd have to say the new fakey leather might be a better fabric for the long-term.
Kelly B
'89 420 SEL, almost bone stock, 142K miles
Wife's ride: '02 Lexus RX300 AWD, all the options but a hitch, 67K miles
'99 Fleetwood Bounder Diesel 39Z diesel pusher motorhome, which has visited 10 Canadian provinces and 49 states under our ownership, 117K miles and many modifications
mckellyb is offline   Reply With Quote
Old 11-27-2007, 11:16 PM   #8 (permalink)
shrimpton's Avatar
Vehicle: '90 560SEL '80 230CE
I agree - MB Tex is bloody amazing stuff.
It needs ZERO maintenance, doesn't fade (over decades!), is neither cold in Winter nor hot in Summer, retains its physical shape really well, provides a secure non-slip surface.... yet is still maligned by the dead animal skin advocates as somehow inferior to leather...go figure?.
Leather is a poor third cousin to MB Tex and MB Velour by my ranking.
shrimpton is offline   Reply With Quote
Old 11-28-2007, 05:45 AM   #9 (permalink)
Yeah, I've been hearing that quite a bit - at least in regards to velour being preferable over leather. I would agree vinyl is a more durable product, but in my mind its still plastic. In the US we are accustomed to believing leather is better even though it's not rational. I guess maybe I have an aversion to dated looking 80's velour with the signature horizontal stripes whereas the leather still looks current. I like the feel of velour...just not the look in my particular car.
An Alcantra interior would be very cool if it was reasonably priced.
Old 11-28-2007, 05:48 AM   #10 (permalink)
I can't tell! Looks real nice.
Previous pix of interior leather upgrade? waterguy R170 SLK Class 3 11-16-2006 01:48 PM
differance of 93-95 e300 s/w SKYDOG W124 E,CE,D,TD Class 0 07-29-2005 10:28 AM
CLK leather interior upgrade bs00clk W208 CLK Class 3 11-20-2004 04:13 PM
Interior Leather, Interior Walnut Burl (HELP!!!) Bryson City Bob Detailing and Car Care 1 10-15-2004 12:02 PM
