» Site Navigation
» Other Sites
Old 10-25-2007, 03:02 PM   #1 (permalink)
mr.xpowerseller's Avatar
Date registered: Sep 2007
Vehicle: 90 300SE (84k Miles) 08 Lexus ES350 Ultra (5k Miles) 07 GMC Sierra SLE (6k Miles) Sold list -->
Post What controls the????
front auxiliary cooling fans on a 90 300SE? Mine appear to be stuck-on. Whenever the ignition is on, the fans are on. They don't over cool the car, but they might with the new rad/flushed cooling system (which is going-in tomorrow).
Is it the:
1.) Radiator Fan Controller/Resistor Your Parts Search Returned 1 Part(s)
2.) Radiator Fan Relay Your Parts Search Returned 1 Part(s)
3.) Radiator/Auxiliary Fan Switch; Blue Insulator with 2 Prong Connector; 130 Degree C Your Parts Search Returned 1 Part(s)
4.) Thermostat; 87 Degree C Your Parts Search Returned 1 Part(s)
I'm guessing #1, but I don't know.
Thanks!
mr.xpowerseller is offline   Reply With Quote
Old 10-25-2007, 03:35 PM   #2 (permalink)
Date registered: Jan 2004
They will not "overcool" the car. Temperature regulation is done by the thermostat. Either the coolant temp sensor switch is stuck "on" or a prior owner jumpered the circuit somewhere to help the A/C.
NordRhein is offline   Reply With Quote
Old 10-25-2007, 05:15 PM   #3 (permalink)
markusfmeyer's Avatar
Date registered: Nov 2005
Vehicle: 86 300SEL Euro, 87 560SEC, 88 560SEC (parts car), 89 560SEL (running again!), 90 300SEL (parts car)
Good place to see if its "jumpered" is the receiver/dryer for the ac. See if there are two pins on the side that don't have wires on them, and instead those two wires are "spliced" or jumpered together. That's one possibility.
markusfmeyer is online now   Reply With Quote
Old 10-25-2007, 07:13 PM   #4 (permalink)
I'll check tomorrow. If it isn't jumped, then what would be exact cause (coolant temp sensor as said above) or should I just leave it be as it won't hurt anything?
Old 10-26-2007, 02:55 PM   #5 (permalink)
Car is off at shop and won't returned until replacement parts come in on Monday or Tuesday, so I cannot check.
If it is jumped or otherwise messed up, should I just leave it be always-on?
Old 10-26-2007, 03:09 PM   #6 (permalink)
Premium Member
cyberdyne's Avatar
Date registered: Sep 2006
Vehicle: 1989 560SEC Euro / 1987 190E 2.3 Euro
Premium Member
Send a message via MSN to cyberdyne
With your warm climate in Florida, I do not think it would hurt to have them on all the time, however you might as well get it fixed and have the car turn them on automatically. That should save wear-'n'-tear on the fans.
- Steve
1989 Mercedes-Benz 560SEC Euro (White Hot!)
1987 Mercedes-Benz 190E 2.3 Euro (For her!)
1988 Mercedes-Benz 560SEL (Sold!)
1988 Mercedes-Benz 560SEC Euro (RIP - Total Loss)
1994 Mercedes-Benz E320 Sedan (RIP - Total Loss)
1983 Mercedes-Benz 380SEL (Sold!)
1970 Mercedes-Benz 250/8 Sedan (Sold!)
cyberdyne is offline   Reply With Quote
Old 10-26-2007, 04:22 PM   #7 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
Most likely your coolant temp or AC pressure switch has wonked out.
Start unplugging what not and it will make itself known
Jonathan
Blue Ridge Mercedes/AMG East
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
86 560SEL AMG 6.0L 32V
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
06 Z4 M Spec 6sp
jhodg5ck is offline   Reply With Quote
Old 10-26-2007, 04:26 PM   #8 (permalink)
brandon671's Avatar
Date registered: Jul 2007
Vehicle: 1990 Mercedes Benz 420 SEL
also if you got this car from a previous owner , they sell connections that will keep your fans on the entire ride, my father did it to his 140 and the engine never breaks 100 now.
brandon671 is offline   Reply With Quote
Old 10-26-2007, 05:03 PM   #9 (permalink)
Jonathan
Can you link me up to both on autohaus? I don't see them. Maybe they are named something else?
Old 10-26-2007, 05:17 PM   #10 (permalink)
Date registered: Jun 2006
Vehicle: '84 500 SEC
Your Parts Search Returned 2 Part(s)
Verify first.
Regards,
Greg
kodiakj2 is offline   Reply With Quote
07 controls in an 04 camdesignerman G-Class 2 05-22-2007 04:54 PM
How do I use the A/C controls? matagin W203 C-Class 3 03-27-2007 05:21 AM
AC controls lights out.... TheOgre W163 M-Class 4 01-19-2006 07:58 AM
Euro A/C controls? iNeon W123 E,CE,D,CD,TD,TE Class 0 04-04-2005 12:33 AM
A/C controls Guest (MBNZ) R129 SL Class 13 04-13-2004 11:23 AM
