» Site Navigation
» Other Sites
Old 10-20-2007, 08:46 PM   #1 (permalink)
NüR-SPEC's Avatar
Date registered: Jul 2006
Vehicle: EURO 500SEL
PCV hose: vac fitting?
this is a pic of the PCV (breather) hose on the passanger side valve cover to the airbox. i'm not sure the euro 500s have the small vac line fitting as seen in the below photo. but if they do, where is this vac line located?
i've used a breather setup, and a catch tank setup and i'm still plauged with fumes in the cabin at speed with the windows down, so i'm going to return it to factory until i figure out a way to isolate the PCV.
TUNINGGRüPPE.COM
NüR-SPEC is offline   Reply With Quote
Old 10-21-2007, 01:51 AM   #2 (permalink)
NüR-SPEC's Avatar
bump!
do the euros even have this vac line fitting? can someone at least verify that for me? or at least tell me where the source is as intended by mercedes benz?
Old 10-21-2007, 02:04 AM   #3 (permalink)
Antipodean host
420 SE's Avatar
Date registered: Sep 2005
Vehicle: 1988 420 SE
Send a message via Skype™ to 420 SE
Yes, my 420 has a vac line that comes off that hose.
Where does it go? I can't quite remember at the moment, I will look in the morning and tell you.
I do recall asking Jonathan if it had anything to do with the trans (which it doesn't) when I was trying to work out if my trans flareing was vacuum related (which it wasn't).
Ross
It's like watching drunk monkeys trying to hump a football...
beware of fundamentalists
420 SE is offline   Reply With Quote
Old 10-21-2007, 07:21 AM   #4 (permalink)
hose
ive got a euro 500sel and the small connection is sealed by a screw being put in
axeman59 is offline   Reply With Quote
Old 10-21-2007, 09:35 AM   #5 (permalink)
mckellyb's Avatar
Date registered: Sep 2007
Vehicle: '89 420 SEL, 142K
I have an actual vacuum line coming off the main hose, but I cannot figure out where it goes. I've been looking and looking, though I've yet to break out the 'mirror on a stick', which is next.
If it's under the throttle body, I'm gonna say screw it and plug it.
Kelly B
'89 420 SEL, almost bone stock, 142K miles
Wife's ride: '02 Lexus RX300 AWD, all the options but a hitch, 66K miles
'99 Fleetwood Bounder Diesel 39Z diesel pusher motorhome, which has visited 10 Canadian provinces and 49 states under our ownership, 117K miles and many modifications
mckellyb is offline   Reply With Quote
Old 10-21-2007, 09:46 AM   #6 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
that breather's vacuum hose feeds into the fuel pressure reg on the Gen II cars..I'm fairly certain it does on the gen I cars as well...it's just been a little while since I stared @ one :-P
Jonathan
Blue Ridge Mercedes/AMG East
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
86 560SEL AMG 6.0L 32V
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
06 Z4 M Spec 6sp
jhodg5ck is offline   Reply With Quote
Old 10-21-2007, 05:02 PM   #7 (permalink)
mckellyb's Avatar
Jonathan
Man, I've gotta score on a decently-valued manual, a real paper one on eBay, one of these days, soon.
CD-based stuff is okay, but it's not quite the same, even when printed.
Fuel pressure regulator, eh? I'll have to dig under there some more.
Old 10-21-2007, 07:24 PM   #8 (permalink)
NüR-SPEC's Avatar
so is this vac line sourced before or after the throttle? is it a vac source for the function of the FPR or a throttle bypass to create vac for the function of the PCV?
Old 10-21-2007, 07:36 PM   #9 (permalink)
Date registered: Nov 2006
Vehicle: '84 380 SEC '82 300 SD '87 300 D
The little vacuum hose goes to the fuel pressure regulator.
B71ZZZ is offline   Reply With Quote
Old 10-21-2007, 07:45 PM   #10 (permalink)
NüR-SPEC's Avatar
hmmm.. as far as i can see, all the lines around the FPR look to be unmolested and i don't see any plugged ends. do you have a pic for refference? or does someone have a schematic from a manual? much appreciated.
won't run after vac. hose off FPR Justin190e W201 190E, D-Class 9 07-30-2007 02:20 PM
F.S. W-140 HEATER HOSE T FITTING rju For Sale, Trade & Wanted Items 0 07-16-2007 08:48 PM
Thermostat on the top hose or bottom hose? guarddog W126 S,SE,SEC,SEL,SD,SDL Class 2 06-01-2007 08:04 PM
FYI: Upper radiator hose t-fitting diameters tucson_sailors W126 S,SE,SEC,SEL,SD,SDL Class 5 05-09-2006 02:37 PM
Steering pump hose ... find new hose type on ebay .... Neno23 W163 M-Class 2 10-19-2004 12:01 PM
