» Site Navigation
» Other Sites
Old 09-21-2005, 07:13 AM   #11 (permalink)
mark2280's Avatar
Vehicle: 1989 MB 560 SEC
RE: Do It Yourself (DIY) repair thread
Antenna Grommet Replacement:
http://www.mbnz.org/forums/forums/thread-view.asp?tid=1184033&posts=2
mark2280 is offline   Reply With Quote
Old 10-16-2005, 10:25 PM   #12 (permalink)
BenzWorld Elite Host
H-TownBenzoboy's Avatar
Date registered: May 2003
Vehicle: 81' 300SD, 82' 300D
Antenna Mast Replacement
http://boostnbenz.1baddsm.com/DIY/Antenna/
Cruise Control Amp Repair
http://www.mindspring.com/~houlihan/merc/cruise.htm
Replacing Glow Plugs OM617, should work for OM603s
http://mbdieseldiy.tripod.com/glowplugs.htm
Adjusting Valves OM617
http://www.jaimekop.com/240D/ValvesFuel/valves.html
Fixing Automatic Climate Control
http://boostnbenz.1baddsm.com/DIY/Climate/
COME TO THE THIRD TEXAS MB GTG, SAT. JULY 26TH 2008
1981 300SD DB881 ext./code #236 leather int. aka: thistle green ext./olive int.
1982 300D, DB877 ext./code #135 mb-tex int. aka: petrol green ext./creme int.
H-TownBenzoboy is offline   Reply With Quote
Old 10-17-2005, 10:05 PM   #13 (permalink)
Date registered: Oct 2005
Vehicle: 87' 560SEL, '97 S420
Nice topic about Cruise Control Amplifier. Also quite often Clutch transistor going bad - CC start hesitate and then quit... If you look at the board from top and 14 pin connector on a left - clutch transitor located by 8001-501 chip on left lower corner it is 40c part....
meanknightgreen is offline   Reply With Quote
Old 10-18-2005, 09:59 PM   #14 (permalink)
Updated links for Fixing Your Climate Control, Renewing Your Instrument Cluster, OM617 Accessory Belt Replacement, and Replacing Your Antenna Mast.
Climate Control
http://www.diymbrepair.com/Climate/
http://www.diymbrepair.com/Antenna/
http://www.diymbrepair.com/Maintenance/Belts/
Renewing the Instrument Cluster
http://www.diymbrepair.com/GaugePaint/
AND as a supplement to the above link
http://www.diymbrepair.com/Dash/
You may have to modify the way you follow these directions for your W126s, but it's just about the same way to do these repairs in the W126 as they're laid out for the W123.
Old 11-11-2005, 09:15 PM   #15 (permalink)
Antipodean
420 SE's Avatar
Date registered: Sep 2005
Vehicle: 1988 420 SE
Send a message via Skype™ to 420 SE
Fuse box legend
Ross
It's like watching drunk monkeys trying to hump a football...
beware of fundamentalists
420 SE is offline   Reply With Quote
Old 11-28-2005, 12:35 AM   #16 (permalink)
Antipodean
420 SE's Avatar
Star removal
Old 11-30-2005, 10:34 PM   #17 (permalink)
Date registered: Nov 2005
AC expansion valve W126
I did a writeup on this job. This is a true (not a cheapo) R134a conversion that has held and worked nicely in hot&humid Washington, D.C. for two full seasons now. I'm not talking about the conversion - all I am explaining is how to replace the expansion valve (which is the first thing to go after a doubtful conversion) yourself for about 90 bucks in parts in one afternoon. This is a job that was quoted to me at several places at over $1,250 (yes, with the r134a conversion already done, so the quote means the refrigerant for the entire system only cost me $15 at Target...).
http://www.funnyyouasked.com/Mercede...t_of_expan.htm
hbofinger is offline   Reply With Quote
Old 12-04-2005, 02:48 PM   #18 (permalink)
Antipodean
420 SE's Avatar
Euro headlight bulb replacement
http://www.benzworld.org/forums/w126...p-removal.html
Old 12-19-2005, 08:52 PM   #19 (permalink)
420SEL Realtor's Avatar
Date registered: Feb 2003
Vehicle: 88 420 SEL
Wow...been a while since I was on line here, but I've just printed about 30 pages on various repair articles.
Great work everyone!
Mark
'88 420 SEL Daily Driver
'83 240D (Manual) SOLD, but always remembered
'83 240D (Auto) SOLD (parts car)
420SEL Realtor is offline   Reply With Quote
Old 12-23-2005, 06:19 PM   #20 (permalink)
Antipodean
420 SE's Avatar
Service schedule petrol/gasoline engines
http://www.mbnz.org/forums/forums/thread-view.asp?tid=1240516
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Richard Gunkel
Fuel System Vacuum Pressure Diagram Needed for W126 '82 SEC GotTheBenz W126 S,SE,SEC,SEL,SD,SDL Class 0 08-05-2007 06:13 PM
85 500sec Euro Vacuum diagram GENEVA W126 S,SE,SEC,SEL,SD,SDL Class 4 02-06-2007 01:55 PM
Purchased 1982 500 SEC...HELP purple heart W126 S,SE,SEC,SEL,SD,SDL Class 17 12-13-2004 05:08 PM
1982 500 SEC stumbles in third gear purple heart W126 S,SE,SEC,SEL,SD,SDL Class 1 12-10-2004 12:48 AM
1982 500 SEC value? mercetaylor General Mercedes-Benz 4 12-19-2003 11:08 PM
