Old 08-21-2007, 09:45 PM   #1 (permalink)
GotTheBenz's Avatar
Date registered: Sep 2005
Vehicle: '82 380SEC, '74 280S
Question Oxygen sensor light
My oxygen sensor light remains on even after changing the oxygen sensor. What does that mean?
'82 380SEC (black, tinted, w/ interior of a '90 560 SEC, heated seats, ps, pm, 6 CD system, DENON pa, 225 Fuzions, wooden steering wheel, shifter, NGKs, ATE brake rotors, 100% synthetically lubricated with AMSOIL),
'74 280S (4 brrl carbs, inline 6 cylinder, chrome wheels, black interior, reinforced springs, super condition, totally gangsta!),
'06 VW TDI Beetle (light & fast, MPG:43+, 175 lbs-foot torque, 1.9 L, 100 hp, Manual 5-speed, Grey+tint)
'81 Santana 525 racing sailboat
GotTheBenz is offline   Reply With Quote
Old 08-21-2007, 10:24 PM   #2 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
It means pull your bulb...early cars O2 systems are very rudimentary..
I believe after 75K the WIS states to pull the bulb.
Jonathan
Blue Ridge Mercedes/AMG East
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
89 190E 2.6 5sp
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
86 560SEL AMG 6.0L 32V
06 Z4 M Spec 6sp
jhodg5ck is offline   Reply With Quote
Old 08-22-2007, 01:12 AM   #3 (permalink)
zviratko's Avatar
Date registered: Jan 2007
Vehicle: W124 400E
Send a message via ICQ to zviratko Send a message via Skype™ to zviratko
o2 sensor has a warning bulb?? where?
zviratko is offline   Reply With Quote
Old 08-22-2007, 08:14 AM   #4 (permalink)
Date registered: Dec 2003
Vehicle: 1989 300SE, 1989 420SEL, 1965 220S, 2002 Ford Crown Vic Police Interceptor
On our cars, it's called the check engine light. It's really the O2 sensor change light. The light, coupled with the duty cycle on the X11 connector, will tell if the ECU is bad.
I've been through this with my 420SEL. I'm getting a replacement ECU soon.
Near Manassas Va. '89 300SE, 2002 Ford Crown Victoria Police Interceptor, 89 420SEL
Had '65 220SE, 67 230S, 72 280SE 4.5 Dad had '65 300SE LWB, '65 220SE
"Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive." C.S. Lewis
wbain is offline   Reply With Quote
Old 08-22-2007, 08:59 AM   #5 (permalink)
jhodg5ck's Avatar
It's different on the gen I cars..works through tweaking the frequency valve instead of feeding tweaking the EHA.
I believe the light is actually on a mechanical trigger, thus the pull the bulb reference in the service literature.
Jonathan
Old 08-22-2007, 09:44 AM   #6 (permalink)
marlinspike's Avatar
Date registered: Feb 2005
Vehicle: 1985 380SE
The light in the Gen 1 is on a mechanical trigger togo off, IIRC, at 60k miles. The official replacement procedure involved removing the bulb from behind the dash.
marlinspike is offline   Reply With Quote
Old 08-22-2007, 02:37 PM   #7 (permalink)
Vehicle: 1991 560 SEL, 1991 560 SEC
Unplug the battery (negative cable) overnight. Put it back on in the morning. It will reset the "check engine" light.
emagic is offline   Reply With Quote
Old 08-22-2007, 02:45 PM   #8 (permalink)
jhodg5ck's Avatar
It's going to be mighty hard to re-set a mechanically triggered CEL/O2 light by unplugging the battery.
Make sure you have your code if you still have the factory becker installed...sometimes the dealers are fussy in giving out said codes.
Jonathan
Old 08-22-2007, 02:57 PM   #9 (permalink)
It worked on my 91 560 SEL. Change the O2 sensor, light still on, disconnected the battery overnight. Connected it back on in the morning. Start the engine, wallaaaaa...... light off. Don't know whether it will work on yours though.
Old 08-22-2007, 03:02 PM   #10 (permalink)
Vehicle: 1990 Mecedes-Benz 420SEL
READ, guys. Jonathan said it's different on the Gen1 cars...
Dave
dave420 is offline   Reply With Quote
ALL Sensor abreviations.. Ex: o2- Oxygen sensor skipinschool W210 E-Class 2 10-19-2006 02:22 PM
Oxygen Sensor 90-500SL R129 SL Class 1 08-22-2005 04:35 PM
O2 - Oxygen sensor wjazz80 W126 S,SE,SEC,SEL,SD,SDL Class 1 07-06-2005 01:24 PM
1985 380se oxygen sensor light thames W201 190E, D-Class 2 06-22-2005 04:54 PM
oxygen sensor zoran W202 C-Class 0 08-05-2004 04:43 PM
