» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Old 06-19-2007, 09:59 PM   #1 (permalink)
Jeff619
Date registered: Apr 2007
Vehicle: 1987 Merc 300SDL
Unhappy Newb Brake Pad Change, Now Brake Fluid Leaking
I think I attempted something out of my league. I changed the brake pads and now my front left brake is leaking out all of my fluid while pressing brake. I can feel pressure but after 2-3 slow pushes the pedal has no back force and fluid is shooting out of my caliper? or brake pad area? or ???? I checked fluid level, went below min mark, I filled again in hopes I did not get air in the lines.... Fat chance at this point I suppose. My friend left with all of his metric tools (I am a newb and have yet to buy a set) but coming in the morning to help again.
Obviously we are beginners but I hope you guys can help me out as I do not want to tow to a shop if at all possible.
Thanks
Jeff619 is offline   Reply With Quote
Old 06-19-2007, 10:37 PM   #2 (permalink)
AzimuthAviation
AzimuthAviation's Avatar
Date registered: Apr 2006
Vehicle: 1982 380SE euro (AMG body and suspension), 1983 300SD, 1984 500SEL AMG euro
Sounds like your caliper is shot. Sounds like your skill level would warrant getting rebuilt calipers for the front. Search for some recent post about the rebuilts and their cost. You'll be done in no time.
AzimuthAviation is offline   Reply With Quote
Old 06-19-2007, 10:44 PM   #3 (permalink)
Jeff619
I just replaced the rotors and calipers (Remanufactured) at shop, but I foolishly thought I could do the back pads myself for practice. Could a caliper be needed already after only three weeks?
Old 06-19-2007, 11:51 PM   #4 (permalink)
AzimuthAviation
I would hope not!!! Why would they install your old pads on new rotors and let you change them later!? Clean things up and see exactly where your leak is. Might just be a cracked hose after changing the caliper, or you got a bum caliper. The hose and bleed fitting are tight, correct?
Old 06-20-2007, 06:50 AM   #5 (permalink)
jhodg5ck
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
Depends on who's re-mans you used. If they are the cheap/crappy re-mans that most online parts houses sell, then yes..you could most. definitely need to replace them again.
I only use Mercedes re-manufactured calipers or new.
Jonathan
Blue Ridge Mercedes/AMG East
Offering Enthusiast Service and Restoration.
Providing quality parts to discriminating customers in all parts of the world.
Located in the Greater Atlanta area
http://AMGEast.com/
*Weekly Updates!*
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
86 560SEL AMG 6.0L 32V
89 300TE
89 560SEC AMG 250/297 mechanical lifter/7K rpm conv.
87 Hammer 6.0L 32V
06 Z4 3.0SI 6sp
jhodg5ck is offline   Reply With Quote
Old 06-20-2007, 01:59 PM   #6 (permalink)
Jeff619
The caliper is cracked, the shop wants $190 for a new one which includes labor. Does this sound about right? I actually was changing back brakes but my friend started without me and took off front caliper. Could he have cracked it by over tightening it? Thanks for the replies.
Old 06-20-2007, 02:06 PM   #7 (permalink)
allnpt0
allnpt0's Avatar
Date registered: Mar 2006
Vehicle: 1983 380SEC: 1985 500SEC
Did the shop carge you for the reman they just put on? Or did you supply them with the parts. If they supplied the parts, it should be under warranty. Most shops including mine will give some sort of parts/labor warranty. He we do 12Mos/12000 mile on most repairs.
allnpt0 is offline   Reply With Quote
Old 06-20-2007, 02:10 PM   #8 (permalink)
Jeff619
I bought the caliper from an online parts place looking to see if they have a warranty but prob not. The new one will come with the warranty.
Old 06-20-2007, 03:15 PM   #9 (permalink)
jhodg5ck
jhodg5ck's Avatar
Yup...I won't install those no matter what you pay me...3rd world offshore rebuilds. Call me crazy buy trusting my life (As well as those around me) to some dude w/ a 3rd grade education making 50 cents an hour does not make me feel all warm and fuzzy..
Jonathan
Old 06-20-2007, 03:28 PM   #10 (permalink)
Jeff619
I am going to have the shop install the new caliper for me because I have no brakes to get it home and don't trust myself with install now. I am worried about the right reman one now. I will get a new one of those as soon as I can. I don't know how I turned a back brake pad job into a front caliper problem. Needless to say it is an expensive lesson in what not to buy and where to draw the line on DIY.
Wish I would have talked to you guys about parts before buying. Thanks for all the info though, it is much appreciated. I would like to learn to do things myself but lack the knowledge. Yes I just publicly announced my incompetence in car repair.
Thanks again,
How To: Brake Pad Change on a 55 slk55er R171 SLK Class 11 08-11-2007 07:28 PM
Brake Pad change questions Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 12 05-21-2006 12:17 PM
Write up on brake pad change danwatt W126 S,SE,SEC,SEL,SD,SDL Class 19 09-20-2005 01:12 PM
Brake Fluid Reservoir Leaking Joey W123 E,CE,D,CD,TD,TE Class 2 02-01-2005 09:44 AM
Help! Brake fluid leaking onto clutch pedal. Lusk W123 E,CE,D,CD,TD,TE Class 5 06-04-2003 11:52 AM
