Old 01-04-2007, 07:31 PM   #1 (permalink)
baskarz's Avatar
Date registered: Oct 2006
Vehicle: '83 280SE
M110 EFI conversion...
i'm looking at converting my m110 engine to full EFI (over time)
was wondering if anyone has had any experience or has done this modification.
also want to know what injectors to use, ecu etc...
i'm an electronics tech by trade but dabble in the automotive in my spare time (i've rebuilt engines in the past as well as non-efi to efi engine replacements in my project camira)
thoughts?
baskarz is offline   Reply With Quote
Old 01-27-2007, 09:45 AM   #2 (permalink)
Date registered: Aug 2006
Hi baskarz
I also own an 83 280SE and am converting to EFI, actually DFI using Megasquirt.
I got the kit assembled and will test it shortly on my test bench (simulator).
I have collected the necessary sensors and am using injectors from a 350SE (high flow) as I am also planning on mapping the EFi to ethanol this summer.
If you are interested in what I have done and my progress, email me privately so that we can exchange notes. I expect to go from 185 hp to 205 and get under 10litres per 100 km at cruising speed.
I also have a bigger throttle body but will not fit this during my actual first build due this spring (march).
My dream is an M110 with 10.5 compression, real camshafts and E85. Such a setup would have more power than a 380SE and use less fuel.
Cheers
Denis
Paris, France
denis.lesperance1@free.fr
Dlespera is offline   Reply With Quote
Old 02-04-2007, 05:36 PM   #3 (permalink)
baskarz's Avatar
Vehicle: '83 280SE
Hi Dlespera
i tried to send you an email, but it was returned due to "inactive email account "
would like to see your progress with the conversion
which version of the megasquirt are you using?
Old 02-06-2007, 08:43 AM   #4 (permalink)
Hi baskarz
My account is active allright but .... go figure...
Try this then : denis.lesperance@atempo.com
I am having trouble getting my Bosch Mercedes OEM sensors calibrated but this is a minor problem.
I have fitted an air temperature sensor from an M116 D-jet to the air cleaner of the M110 and fitted a coolant sensor of the same source on the right side of the M110 block.
The system is operative on the test bench. Now comes the time to test it on the actual car.
Keep in touch !
Denis
Paris, France
Old 10-12-2007, 01:15 AM   #5 (permalink)
cguenther's Avatar
Date registered: Jun 2003
Hi,
im in the process to shift a M110 engine from k-jetronic to MS2 V3.0. The setup works fine, MS2 is doing spark for now. fuel is still on the k-jetronic.
does anyone has megasquirted a M110 before and can post his ignition advance table?
thanks a lot!
best regards
carsten
... WDB1290681F202xxx ... classic-roadster.de ... WDB1290761F187xxx ...
cguenther is offline   Reply With Quote
Old 10-12-2007, 01:51 AM   #6 (permalink)
StreekG's Avatar
Date registered: Oct 2005
Vehicle: 1978 C123 280CE, 1988 500SEC
Send a message via MSN to StreekG
Good luck on the conversion guys, i was going to do the same thing with my 280CE W123 but now im selling it, and working on the 500.
StreekG is offline   Reply With Quote
Old 10-12-2007, 06:48 PM   #7 (permalink)
Boardmonger's Avatar
Date registered: Feb 2005
Vehicle: 83 300d turbo, 79 c123 AMG
I will be watching this closely. I'm scared of the fuel map, but want to do the conversion.
-Zack K.
1983 300d Turbo (Daily Driver) -- 243,000 miles
1979 280ce AMG (Beginning extreme restoration) -- 141,410 miles
1981 300d Euro 4 speed -- 188,421 km -- Sold
1979 300d Euro 4 speed -- 265,000 miles -- Brother's
1995 E300 Diesel -- 37,000 miles -- Dad's
A Collection of w123 AMG Cars and Parts
Boardmonger is offline   Reply With Quote
Old 10-12-2007, 09:52 PM   #8 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
Mapping shouldn't be scary..you can auto tune for a base map w/ MSII and fine tuning is a matter of dyno time and a willingness to push that map around;-)
Jonathan
Blue Ridge Mercedes/AMG East (temp down!)
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
89 190E 2.6 5sp
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
86 560SEL AMG 6.0L 32V
jhodg5ck is offline   Reply With Quote
Old 10-14-2007, 01:51 PM   #9 (permalink)
cassel's Avatar
Date registered: Aug 2004
Vehicle: 500sec & 560sec
EFI Conversion
Baskarz, I'm in the process of converting my 560 to EFI. Started the project using Megasquirt, but, changed direction and I'm going with a different custom designed system. It's not difficult just takes time to customize parts and tune properly. If you want more info PM me.
cassel is offline   Reply With Quote
Old 10-14-2007, 03:41 PM   #10 (permalink)
StreekG's Avatar
560 isn't EFI already?
I swear i spotted a computer on my 500... looked up specs it says multipoint efi.
M103 owners: would you like EFI? am3037 W126 S,SE,SEC,SEL,SD,SDL Class 4 04-15-2007 10:32 PM
for sale 1972 280 sel 4.5 efi thorogood32@hotmail.com For Sale, Trade & Wanted Items 0 12-13-2006 03:58 PM
EFI electronic wesley06 W201 190E, D-Class 2 09-16-2006 02:41 PM
First part of the M103 EFI system, nearly done am3037 W126 S,SE,SEC,SEL,SD,SDL Class 2 07-20-2005 05:00 AM
EFI Computer Malfunction symptoms krokodileman Vintage Mercedes-Benz 0 05-18-2004 07:27 PM
