» Site Navigation
» Other Sites
Old 09-26-2006, 01:57 PM   #1 (permalink)
Date registered: Sep 2006
Vehicle: 1984 500 SEC, 1969 Pontiac GTO
Chevy Conversions
Hi I hope you guys can help a newbie out. I'm looking at a fantastic bargain one-owner 380 SEC in immac condition. However, the motor feels underpowered...and I've got a chevy 327 lying around. I'm wondering if this is a difficult conversion. I'm sure there is already a thread or several on this topic, so I'd appreciate any direction towards any useful ones.
Thanks for your help
Rob Muirhead
rob@telkomsa.net
JoburgFiveO is offline   Reply With Quote
Old 09-26-2006, 03:05 PM   #2 (permalink)
Michael Pillay's Avatar
Date registered: Oct 2003
Vehicle: 1990 300 SEL
Cant offer any advice about the Chevy conversion, but I'll say welcome to a fellow South African.
Mike
1990 Mercedes Benz 300 SEL
2001 Mercedes Benz ML320
1999 Mercedes Benz SLK230
1986 Porsche 911 Carrera
Michael Pillay is offline   Reply With Quote
Old 09-26-2006, 03:50 PM   #3 (permalink)
mramay's Avatar
Date registered: Feb 2005
Vehicle: '87 570SEC & '87 560SEL
Welcome to the site. I believe that a US V8 in place of a 380 engine is exactly the right thing to do.
I'm prejudiced though since I'm in the middle of putting a 2002 Corvette LS6 engine into my '87 560SEC.
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 18x8.5, ATE slotted rotors with semi-metallics, BergWerks FGS, 3.07 Limited Slip.
In progress - FrankenBenz SEC: GM LS6 5.7L engine with custom 4L60E 4-spd overdrive transmission, GM rack and pinion.
There is a very fine line between "hobby" and "mental illness."
mramay is offline   Reply With Quote
Old 09-26-2006, 03:52 PM   #4 (permalink)
500MPL's Avatar
Date registered: Jan 2004
Vehicle: 1984 500 SEL euro, 1989 560 SEL, 1980 450 SL, 1981 DeLorean
Welcome,
Look at the threads that mramay has posted regarding his project. It is no easy task and Mike has spent countless hours working out every detail.
Good luck and best wishes.
Regards,
500MPL is offline   Reply With Quote
Old 09-26-2006, 09:03 PM   #5 (permalink)
The Doggfather's Avatar
Date registered: Aug 2006
Send a message via MSN to The Doggfather
In the last couple of days, I've also been thinking of dropping a Chevy in for my SEL project. I've got the perfect engine in mind - a 454 small block Chev with alloy heads and 600hp! To back up the engine's massive power & torque (575Lbs to be precise), a purpose built TH350/400 fully kitted auto will be fitted into the tranny tunnel, along with a modified/custom tailshaft and a 3.46 LSD to really get things moving.
I think this will prove to be a very nice setup indeed!
Check out the engine and spec sheet ..
http://www.rocketindustries.com.au/d...artno=WP101011
In regards to the 327 Chevy you've got lying around - one word...NICE! They are a very nice engine!
Good luck man, it should be a pretty straight forward fit once you get the mounts made up. You may have to modify your crossmember or adapt a suitable Chevy crossmember which will be a little PITA, but the only major headache I can think of may be the headers, due to the big lump of a steering gearbox which gets in the way on one side of the engine. It will be a tight squeeze, but it can be done. I'd say it will be a custom job. Alternatively, you can do what Mike is in the process of doing, and that's a rack & pinion steering setup. This way you shouldn't have any problems with the headers!
Btw, how much hp is the 327 making, do you know?
The Doggfather is offline   Reply With Quote
Old 09-26-2006, 09:08 PM   #6 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
I don't think a TH400 is going to give you the gearing you want.. Instead I would look to something w/ an OD...esp w/ a 3.46..the car would be horrendous on the highway.
Jonathan
Blue Ridge Mercedes/AMG East
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
86 560SEL AMG 6.0L 32V
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
06 Z4 M Spec 6sp
jhodg5ck is offline   Reply With Quote
Old 09-26-2006, 09:17 PM   #7 (permalink)
Alot of people use the TH350/400 autos behind their Chevys. They are very strong, will be geared to suit the engine, and I could always fit a Gear Vendors O/D later if necessary.
A 3.46 I think will be fine, but I'm open to ideas.
What do you suggest I go with Jonathan?
Old 09-26-2006, 09:51 PM   #8 (permalink)
hammerfan1's Avatar
Date registered: Apr 2006
Vehicle: Currently a 1988 Acura Integra, getting a 560SEL soon
I think you would be better off, as far as Chevy transmissions go, with a 700R4 or 4L60, as they are 4 speed with overdrive which will make the engine not go through as much gas.
"Tell me somethin', Its still we the people, Right?"
Peace Sells- Megadeth
hammerfan1 is offline   Reply With Quote
Old 09-26-2006, 10:07 PM   #9 (permalink)
Yeah you've got a point, but this engine is going to be guzzlin the juice like mad anyway (600hp, solid cam), so I think I'll go with a tranny that I know for sure will handle the power.
I think the transmissions you have mentioned are for the newer LSx motors, not to say it can't be fitted to an old SB, but I think it makes sense to keep 'oldskool with oldskool' and 'newskool with newskool'. Just my opinion.
Old 09-27-2006, 07:00 AM   #10 (permalink)
jhodg5ck's Avatar
I'm not sure the 700 would like that kind of torque.. I would look to the (I beleive) 4L80E (they use it in trucks). To my knowledge a TH400 was always a 1-1 in high.
I know they can take the power, we just sold our 70 Buick GSX factory St 1 but by the time we were done w/ it St. 3.
Jonatan
Best Engine Conversions Yet dahappybanana General Mercedes-Benz 5 03-25-2006 12:39 PM
Diesel conversions warren t G-Class 11 01-19-2006 08:15 AM
Compression conversions Michael Bond Vintage Mercedes-Benz 1 08-08-2005 11:45 AM
Smart Car Conversions Mark Cummins smart 2 12-17-2004 12:09 PM
SLK + Chevy S-10 + Hold your nose when you sneeze = Chevy SSR! (5 picts) Douglas-Indianapolis R170 SLK Class 3 10-09-2001 08:08 PM
