Old 06-22-2006, 04:16 PM   #1 (permalink)
bse500sel's Avatar
Date registered: Sep 2004
Vehicle: 1985 500 SEL
Smile MPG is so much better now...
I have posted about my car's high idle problem in the past, but I just wanted to give everyone an update. The fix for my car turned out to be the Idle Control Unit. I knew that there would be some benefits to getting this repaired. I was just hoping that it wouldn't destroy the transmission before I was able to get it fixed. I always cringed when I had to put the car into gear. Well I cringe no longer, and to top it off my gas mileage is awesome. With a fill up on Monday, I have driven 296 miles and still have a third of a tank of gas to go. This is great when you consider that I was only getting between 225 to 250 miles to a full tank before the repair to the ICU. The 500SEL is not econo-box by any stretch of the imagination(Thank God), but it sure feels better to know that I won't see the gas pump as often.
The 296 miles are all highway miles running between 70-80mph.
If I have said it once, I will say it again.... This is a great car.
Thanks to everyone for all of your help in diagnosing the problem.
bse500sel is offline   Reply With Quote
Old 06-22-2006, 07:47 PM   #2 (permalink)
enigmamdw's Avatar
Date registered: Jun 2005
Vehicle: 1983 380 SEL
Send a message via AIM to enigmamdw Send a message via Yahoo to enigmamdw
So THAT's what I have to look forward too when I get mine.
AWSOME!!
enigmamdw is offline   Reply With Quote
Old 06-24-2006, 05:45 PM   #3 (permalink)
neil.b's Avatar
Date registered: Nov 2003
Vehicle: 1984 euro 500sec
where is the unit located?
neil.b is offline   Reply With Quote
Old 06-24-2006, 06:53 PM   #4 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
You'll prob. find that once you pass a 1/2 tank it will go a bit quicker then the 1st half..every single gas 126 I have owned has been that way.
Seeing 19-22 mpg is not unheard of in these cars. My record was a hair under 24 w/ my 560SEL.
The idle control unit is under the passenger side floor panel.
Jonathan
Blue Ridge Mercedes/AMG East
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
89 190E 2.6 5sp
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
86 560SEL AMG 6.0L 32V
06 Z4 M Spec 6sp
jhodg5ck is offline   Reply With Quote
Old 06-24-2006, 09:25 PM   #5 (permalink)
dtkw's Avatar
Date registered: Jun 2003
Vehicle: 86 560SEL
I got 360 miles in one tank on one trip. It was in the Fall and no aircon running.
dtkw is offline   Reply With Quote
Old 06-30-2006, 11:34 PM   #6 (permalink)
DinoMobile's Avatar
Date registered: Jan 2006
Vehicle: 1990 560SEL
Question
Jonathan
Jonathan,
Do you know if a faulty idle control will cause oscillating idle? In P or N (no load) idle will "rev" on its own from 600~800, but in D (with load) idle's fine.
Current problems are CHECK ENGINE LIGHT on, shakey motor at "no load" idle, and unable to pin point any vaccum issue. Plugs and wires are very new and was checked ok.
I tried to re-solder the points inside the idle control unit, but no help. When unit is flexed left and right, idle will rise to ~900rpm.
I plan to change o2 senor this week, do you think it'll solve my problem? My mpg/miles for tank had raised from 270mi to 320 w/ 20 gal fill, same commute and after check engine light came on...
Brian
DinoMobile is offline   Reply With Quote
Old 07-01-2006, 04:58 AM   #7 (permalink)
jhodg5ck's Avatar
when was the last time your o2 was changed? what plugs are you running?
How old are the motor mounts? Ever do a compression test?
hunting idle is Usally a vacuum leak IME.. WHen you are stopped in drive where does your economy gauge sit?
Jonathan
Old 07-01-2006, 10:20 AM   #8 (permalink)
DinoMobile's Avatar
Jonathan,
IMO, it is vaccum too. Maybe I'll have to look harder, but I really don't know where to start except for the water trick over injectors.
I noticed the economy gauge is opened to the right a little, more during the slowing down let say from 40mph to a stop.
I'm running superplugs w9dc gapped .38, o2 sensor was replaced 15k ago, but it's probably shot from improper adjustment on the mixture. (way rich) I think the mechanic had done so to compensate for a plugged fuel port in the FD. (FD is new now)
Motor mounts are new 15k ago, and never check compression.
Thanks in advance,
Brian
