» Site Navigation
» Other Sites
Old 06-05-2006, 10:24 AM   #1 (permalink)
graftdesign
Date registered: Apr 2006
Vehicle: 1990 560 SEL, 1991 560 SEC Euro 75k
Engine operating temp
Does anyone know what the normal operating temperature range is for a 560 SEL? I realize it depends on the type of driving you do. I'm concerned about mostly city driving. My gauge reads between the 80c and the line before 120c when it was 87F. I'm assuming that's 100c. I always get a little nervous when it reaches the 100c mark but would like to see what everyone else averages. I live in Michigan where the outside temp flunctuates from low single digits in the winter and 90+F in the summer. The manual suggests normal engine temp can run up to just before the red line... but that would make me real nervous!
graftdesign is offline   Reply With Quote
Old 06-05-2006, 10:44 AM   #2 (permalink)
jhodg5ck
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
All my cars run b/w 80-87 depending on temp/traffic and the AC. highest I've seen was about 95 when it was 100 or so degrees out, stuck in traffic w/ the AC on full.
jonathan
Blue Ridge Mercedes/AMG East
Offering Enthusiast Service and Restoration.
Providing quality parts to discriminating customers in all parts of the world.
Located in the Greater Atlanta area
http://AMGEast.com/
*Weekly Updates!*
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
86 560SEL AMG 6.0L 32V
89 300TE
89 560SEC AMG 250/297 mechanical lifter/7K rpm conv.
87 Hammer 6.0L 32V
06 Z4 3.0SI 6sp
jhodg5ck is offline   Reply With Quote
Old 06-05-2006, 11:47 AM   #3 (permalink)
graftdesign
Thanks Jonathan. So I guess I'm close to normal or just slightly below normal compared to your 560. I had my AC going as well when mine gauge hit the 100c mark, but then again I didnt have 100 degree outside temp either (hi 80's). I guess I'll have to see what happens when it gets hotter. In short no need to worry yet... correct?
Old 06-05-2006, 12:03 PM   #4 (permalink)
jhodg5ck
jhodg5ck's Avatar
Eh...I don't really like to see them traveling up that high w/ regularity. When was the last time your cooling system was looked @/maintained? The coolant should be changed @ least every 2 years. How is your fan clutch? One morning before you start the car go out and see what kind of resistance you encounter when you spin the fan.. Then get the car up to temp and when you park check it again. It should be a good bit harder to move.
Also, you might try adding a container or two of Redline's Water Wetter.
Jonathan
Old 06-05-2006, 03:49 PM   #5 (permalink)
500MPL
500MPL's Avatar
Date registered: Jan 2004
Vehicle: 1984 500 SEL euro, 1989 560 SEL, 1980 450 SL, 1981 DeLorean
Also check the aux. temp sensor to see if it is engaging the fans. There is a link for a resistor that will lower the cooling fans down from 105* to 95*. That made a difference in my 560.
Regards,
500MPL is offline   Reply With Quote
Old 06-06-2006, 04:26 PM   #6 (permalink)
reddman
Vehicle: 1986 560SEC
Greetings to all ~
I am new to 126 ownership -- recently purchased a 1986 560sec (black w/palamino interior) with 98K... Great Car!
You mentioned the resistor upgrade and I found the following link(http://pages.prodigy.net/jforgione/MB_S500.html) is this what you were refering to? If so do you recomend the upgrade.
I have had a lot of fun learning about my car on this forum -- my compliments to all.
Red...
reddman is offline   Reply With Quote
Old 06-08-2006, 05:43 AM   #7 (permalink)
graftdesign
Jonathan
Thanks again Jonathan. So you are saying that if the gauge reads between 80 and 120 (at around 100 I'm guessing) then that's NOT normal? I just bought the car a month or so and know the radiator was changed last year. I normally reads at 80c and only goes higher when the weather is in the upper 80's and above.
I'll give the Redline a try.
Old 06-08-2006, 05:57 AM   #8 (permalink)
mramay
mramay's Avatar
Date registered: Feb 2005
Vehicle: '87 570SEC & '87 560SEL
With a pressurized system, 120 C is not boiling and the engine is fine. I see 110 C fairly often when Las Vegas is 105F and I'm stopped in traffic. My engine temperature gauge, in C, makes a reasonable outside air temp gauge, in F, when the temperature gets above around 85. If it is 95F outside, the engine seems to run 95C, etc. No problems, nothing wrong, it's just the way it is.
Blasphemous Mike
US '87 560SEC with Euro headlights, clear markers, H&Rs, 18x8.5, ATE slotted rotors with semi-metallics, BergWerks FGS, 3.07 Limited Slip.
In progress - FrankenBenz SEC: GM LS6 5.7L engine with custom 4L60E 4-spd overdrive transmission, GM rack and pinion.
There is a very fine line between "hobby" and "mental illness."
mramay is offline   Reply With Quote
