Old 04-24-2006, 01:42 PM   #1 (permalink)
ak380sec's Avatar
Date registered: Sep 2005
Vehicle: 1982 380sec
Injectors
I bought injectors for my 380 sec off ebay, didn't look at the numbers when I received them. They sat for the winter so contacting seller seems a mute point. Whent to install them it looks like they are for the 117 500 and up engines. 380 injectors # are 0437502047, injectors I have new are # 0437502054, they look similar however the line hookup threads are much finer than the old ones. Question is If I had new lines made to fit them would they work? or could I run into a rich running condition?
ak380sec is offline   Reply With Quote
Old 04-24-2006, 02:31 PM   #2 (permalink)
48hp's Avatar
Date registered: Feb 2004
Vehicle: 1985 500SEC
The 380 and 500 use the same injectors. 0437502047(116.963/117.963). The are for the 560. 0437502054(116.968). Not worth changing all of your fittings.
48hp is offline   Reply With Quote
Old 04-24-2006, 08:01 PM   #3 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
drop me a line, we might be able to work something out to get you the correct injectors...chaging the line ends is the Wrong way to go about things.
Did you get new seals/cups/orings as well? To change just the injectors and not the other bits will result in vacuum leaks gallore!
Jonathan
Blue Ridge Mercedes/AMG East
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
89 190E 2.6 5sp
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
86 560SEL AMG 6.0L 32V
06 Z4 M Spec 6sp
jhodg5ck is offline   Reply With Quote
Old 04-25-2006, 05:57 PM   #4 (permalink)
ak380sec's Avatar
I only bought injectors, I cleaned th eold ones and reinstalled them. I have another concern though, this engine is very large and there is a sticker on the radiator support that says something to do with us imissionsand imports and below it is a number 123/116.036. I looked under at bottom of engine and found this #117 014 00 20. I took pics but they seem to be to large to post here. The diff # is12635108. Oh! this engine has a double row timing chain, has an O2 sensor but will not run with fuelrelay in. I'm really confused now.
