» Site Navigation
» Other Sites
Old 01-03-2006, 12:45 PM   #1 (permalink)
Minkoff's Avatar
Date registered: May 2004
Vehicle: 1985 500SEC
500 SEC Rough Idle
My 1984 500 SEC just developed a rough idle. Runs perfect other than the idle. I poked around looking for a vacuum leak, no leaks, wires have less than 10,000 mi
I took off the distrib cap and noticed the rotor looks a little burnt and worn. Could this cause a rough idle??
I did a search but no help. Any advise???
Minkoff is offline   Reply With Quote
Old 01-03-2006, 12:51 PM   #2 (permalink)
Minkoff's Avatar
RE: 500 SEC Rough Idle
Just got back from a 1200 mile trip the car ran perfect.
20-22 MPG 80-90 MPH
Old 01-03-2006, 02:46 PM   #3 (permalink)
560se's Avatar
Date registered: Jun 2004
glad to hear that! ive still havnt been able ti run my 500se[xx(]
560se is offline   Reply With Quote
Old 01-03-2006, 04:27 PM   #4 (permalink)
jdc1244a's Avatar
Date registered: Oct 2004
Send a message via Yahoo to jdc1244a
The same for my 500 SEL: strong and perfect on the open road but lumpy idle at the traffic lights. I don’t drive it to the city anymore. If no vacuum leaks look for air leaks. It could be the rotor but if bad poor engine performance would be more consistent, as you’d notice problems at highway speeds.
Some owners look for air leaks with a spray can of carb cleaner, others use a spray bottle with water. You know you’ve found the leak when the engine smooths out for a second or tries to stall, depending on which method is used. I don’t care for either method and unless another comes along I’ll give the carb cleaner method a try.
jdc1244a is offline   Reply With Quote
Old 01-03-2006, 05:52 PM   #5 (permalink)
Minkoff's Avatar
Where specifically should I spray carb cleaner?
Do I only have to remove the air cleaner for this test?
Thanks!
Old 01-04-2006, 09:59 AM   #6 (permalink)
Minkoff's Avatar
I know you gurus know where to spray the wd40 to check for leaks
Old 01-04-2006, 10:09 AM   #7 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
around the injectors, the air distribution hoses (all the black hoses runing to and around your intake manifold). Also spray down below the throttle plate (around where the rubber boot attaches to the lower intake manifold).
I'd also check off the back of your intake manifold (passenger side)..you should have 18-18inches of Steady vacuum.
I know your wires are new but I would check them w/ an Ohm meter anyway..sometimes things go wrong :-P
Good luck!
Jonathan
Blue Ridge Mercedes/AMG East
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
86 560SEL AMG 6.0L 32V
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE (parts)
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
06 Z4 M Spec 6sp
jhodg5ck is offline   Reply With Quote
Old 01-04-2006, 12:51 PM   #8 (permalink)
Minkoff's Avatar
Thanks for the help I went and changed the cap and rotor.
No Help, was not a bad idea to change anyway, it was time. i feel like an idiot. The culprit was a simple vacuum leak. The vacuum line from the power brake booster simply fell off. I went ahead and changed the rubber mounts for the air cleaner, one was broken.
Old 01-04-2006, 01:58 PM   #9 (permalink)
Minkoff's Avatar
Someone on this form said ALWAYS! start with the simple things. Nothing worse than a car that "idles" Shi.....
I would rather park it.
