RE: gear shifter progress made, i think.. have a look please
vdub... there's something wrong with the hub instalation on the steering colomn. There shouldn't be that much gap between. Try re-adjusting it because you might run into problems in the future with stuff(read junk and dust) building up and screwing with the way you steer. Just my oppinion.
__________________ 1990 Mercedes-Benz 560SEL soon to be Euro-spec clone AMG (summer of '09) 1991 Mercedes-Benz 190E AMG (undergoing restoration: July 1 - October 17, 2008)
Nothing wrong with the installation of the steering wheel and boss - except that it is not the correct design for the w126.
You need the original AMG hub/boss, on which the end overlap plate is wider and hence covers that gap. Have a look on german ebay searching for 'Mercedes lenkrad nabe'.
The lip on the original AMG/MB boss is noticeably wider.
If your'e still wanting to glue the wood try "Maverick Bond" My glove box vaneering was starting to part from the aluminium backing & after tubes of superglue, contact glue etc. I came across this product - it stuck first time & has never budged.
www.maverick-co.com/products/bond/index.asp
talbir - 5/4/2005 10:47 AM
Can you point me to a picture or show one what a w126 hub or "boss" as they may say it in the UK looks like? I don't see a difference.. but maybe you can point out something that I don't see.
Attached are a couple of pics, showing the AMG wheel and boss on my euro 500SEC AMG. I have the same boss on my euro 560SEC, but different style original w126 AMG steering.
Not even a hint of a gap - and the boss styling pattern matches EXACTLY that of the steering column shroud. It's a perfect match - the original AMG boss is the one to use.
