over the years i've heard many variants of how to check the oil level.
1. stone cold.......(first thing in the morning)
2. after engine has run for 5 minutes
3. any time.....even if the car has just run 100 miles.
what exactly is the proper way and which method gives you the most accurate reading..... or at least the one that matters.
Current:
1989 Mercedes Benz 300SE
2000 Mercedes Benz S430V
2000 Mercedes Benz E200
1965 Mercedes Benz 220SEb
The owner’s manual says to check it when the engine is at operating temperature and “the operating temperature should have been obtained for some time.�
So check after - I would say - at least a half-hour of driving.
1991 300 SE (w126.024/M103.981) 140,000 miles
I think we’ll all agree that the auto box fluid level is checked hot, with the engine in idle (after running the P-R-N-D-3-2 course and back again) on level ground; the level should be between the MIN and MAX marks. MB says not to use a paper towel or cloth rag, it will contaminate the fluid; I use an old chamois.
