» Site Navigation
» Other Sites
Old 12-28-2003, 07:05 AM   #1 (permalink)
dingo's Avatar
Date registered: Dec 2003
Vehicle: '86 560 SEL '85 300D
1986 300SDL stall problem - help!!!
Have a '86 300SDL with 160k miles that loses power then stalls after 5-10 mins of running. If you let it cool for about 15 mins it starts up again but the same thing happens after 5 mins or so.
It has new
diesel fuel injection pump
starter
alternator
ac compressor
belts
seals
filters
exhaust
hoses
fuel tanksstrainer and filter
there are no oil leaks anywhere
any ideas?![?]
dingo is offline   Reply With Quote
Old 12-30-2003, 04:55 PM   #2 (permalink)
Where's my auto-leveling?
AndyFracica's Avatar
Date registered: Sep 2003
Vehicle: '06 ML350 '03 E320
RE: 1986 300SDL stall problem - help!!!
dingo - 12/28/2003 9:05 AM
It has new
starter
alternator
ac compressor
belts
seals
filters
exhaust
hoses
any ideas?![?]
Dingo,
I have an '87 300SDL with almost 190,000 miles on it. It runs great and I have never had the kind of problem that you are describing.
You have changed all of the filters that I would have suggested,
You didn't say anything about the injector nozzles they may be clogged or dirty. Have you used any injector cleaner or pulled them out and cleaned or replaced them?
Another question, Have you changed the timing chain? I changed mine at 120,000 miles.
If the timing chain is worn, it stretch when it heats up and throws off the timing. (stranger things have happened).
I hope this gives you some help.
Andy
Andy
2006 ML350
723 - Pewter, 104 - Macadamia Interior, H04 - Brown Birds Eye Maple Wood, 167 Standard Non-Sport Pkg, 317 Comfort Pkg, 318 - Trim Package, 319 - Lighting Package, 320 - Entertainment Pkg, 324 - Sunroof Pkg, 580 - Std. Climate Control, 873 - Heated Front Seats, 890 - Power Liftgate, Navigation System, iPod interface kit
Modifications:
Added: Chrome Door handle cups, MB Twin Spoke 5-Spoke 18" wheels and tires
AndyFracica is offline   Reply With Quote
