» Site Navigation
» Other Sites
Old 12-08-2003, 02:26 PM   #1 (permalink)
Date registered: Oct 2003
Vehicle: 420 SEL
Timing chain replacement/timing issue 1990 420SEL
I had a problem where I found a broken chain guide. I removed all the bits and replaced the guide, while I was there I replaced the timing chain and tensioner trying to make sure the engine timing stayed the same as I threaded in the new chain while removing the old one. Everything appeared OK untill I turned the engine over and it appears that the chain on the right side cam, looking from the front, is loose on the sprocket and is trying to jump teeth.
Is there a quick way to check the mechanical timing to make sure I am not out of time? Marks on the cam shafts etc...
Thanks in advance.[?]
supersport6 is offline   Reply With Quote
Old 12-09-2003, 02:03 PM   #2 (permalink)
BenzWorld W126 & W201 Host
spanners's Avatar
Date registered: Feb 2003
Vehicle: 1988 420SE, 2002 C180 Kompressor, 200 ML320
Send a message via MSN to spanners
RE: Timing marks
Look on the top of the first cam pillar and in the middle, you should see a raised line.
Then as you turn the engine, you should see a "V" cut out in the cam shaft collar near the pillar. Line the "V" with the line on both sides when the engine is at TDC.[;)]
Work is the curse of the drinking class!
spanners is offline   Reply With Quote
