So... I did not notice this issue until i put the rims on. The kijiji add had the flat faced rim as pick (OEM), turned out to have a sink on the face (W202 C class)
The rears clear, the front does not clear the caliper. I put 5MM spacers on, and just barely rub on the caliper - My solution is to go to a 8mm spacer with longer bolts.
My concern is, do these rims support the V8 engine? I drive a 92' 400E.
Thanks,
Thanks,
