95 E320 high pressure A/C hos exploded, cant find the part anywhere - Mercedes-Benz Forum
post #1 of 24 (permalink) Old 06-17-2017, 12:55 AM Thread Starter
Date registered: Jun 2017
Vehicle: 1995 E320
Quoted: 2 Post(s)
While driving today the bottom A/C hose burst where the high pressure check valve is going down to the something??? I can't seem to find any diagrams for the ac or anything to figure out what the part is the hose connects to or if I need that whole assembly and If so where to find it. Please help its getting hotter and hotter outside.
320forME is offline
post #2 of 24 (permalink) Old 06-17-2017, 01:34 AM
Trevor Hadlington's Avatar
Date registered: May 2016
Vehicle: 1989 W124 260E Saloon.
Quoted: 151 Post(s)
320forme Can you go to Google search ? if so look up to the r/hand side and click on images
Then in the search box put- MERCEDES E320 1995 AIRCONDITIONING DIAGRAMS .Then search the diagram you need to find your part .
Other is to visit MBZ PARTS same again put in your year and make . Let us know if its any help to you.
Trevor Hadlington is offline
post #3 of 24 (permalink) Old 06-17-2017, 02:45 AM Thread Starter
Vehicle: 1995 E320
Quoted: 2 Post(s)
Thank you for the reply, I have tried both and no diagram I have found matches what I am seeing under the hood.
320forME is offline
post #4 of 24 (permalink) Old 06-17-2017, 03:05 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1018 Post(s)
I think you are talking about the condenser to receiver/dryer hose.
That hose is MB p/n#1248304915. List price is about $55
You will also need 2 of the following seals. MB p/n#1409970645
sbaert is offline
post #5 of 24 (permalink) Old 06-17-2017, 03:22 AM Thread Starter
Vehicle: 1995 E320
Quoted: 2 Post(s)
That's not it, that is the only part I have found, I will try and take some pictures and upload them here it has the high pressure port connected to it...
320forME is offline
post #6 of 24 (permalink) Old 06-17-2017, 06:46 AM
Date registered: Sep 2015
Vehicle: 1994 E320
Quoted: 70 Post(s)
I had some trouble finding one of my AC lines. I took the line to a hydraulic shop and had them re-use the fittings at the end and use high pressure rubber hose to replace the bad section of pipe. But if the fittings or valve is destroyed, that likely won't work.
E320Project is offline
post #7 of 24 (permalink) Old 06-17-2017, 09:40 PM Thread Starter
Vehicle: 1995 E320
Quoted: 2 Post(s)
the fittings look fine to me, what kind of hydrolic shop did you go to?
320forME is offline
post #8 of 24 (permalink) Old 06-18-2017, 02:42 AM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 93 400E, 95 320TE, 95 E320, 98 S500
Quoted: 714 Post(s)
Any hydraulic hose shop can do it. Your profile isn't complete, but assuming you're in the US, get in the yellow pages or use Google to find a shop near you.
Sent from my XT1080 using Tapatalk
Jayare is offline
post #9 of 24 (permalink) Old 06-18-2017, 05:29 PM
Date registered: Dec 2012
Any of the E240or E280 or c240 or c280 will fit on that body the compressor sits at the bottom of the motor on all ov the v motors.....good luck
Sent from my GT-N8000 using Tapatalk
alf_hockly is offline
post #10 of 24 (permalink) Old 06-18-2017, 05:55 PM
Jayare's Avatar
Quoted: 714 Post(s)
On the M104, IL6, the compressor is on the lower left front the of the motor.
Jayare is offline
