Help: Shock absorber protector installment - Mercedes-Benz Forum
post #1 of 31 (permalink) Old 04-18-2017, 01:55 AM Thread Starter
Date registered: Mar 2007
Vehicle: 1990 300E 2.6
Unhappy Help: Shock absorber protector installment
Hi, I've been trying to fit new shock absorber protections on front struts. However, they don't hang from bottom of the strut mounts. I called the shop to send them in case they are wrong size. Today I got the exactly same size ones. Their top parts are too small to fit to the bottom of the mounts.
Since my old protections are all gone, I don't know how supposed to look like. I search all over the internet but could't find the answer. Help!!
valensf is offline
post #2 of 31 (permalink) Old 04-18-2017, 02:27 AM
sbaert's Avatar
Date registered: Jun 2007
Vehicle: '95 E300 DIESEL, '91 600SEL, '92 600SEL
Quoted: 1015 Post(s)
Are you talking about the bump stops?
In that case, you need to pull the shock, remove the boot, and then reinstall the new bump stop
sbaert is offline
post #3 of 31 (permalink) Old 04-18-2017, 11:42 AM Thread Starter
Help: Shock absorber protector installment-img_5737.jpg
Thank you, sbaert.
I am talking about not the bump stop but the boot. I've replaced with new strut, strut mount, new bump, and trying to fit the boot. Here in the photo, top of the boot is not small enough to fit inside of the mount over the bump stop(yellow in the photo) or big enough to go over the edge of the mount. I have no idea!
valensf is offline
post #4 of 31 (permalink) Old 04-18-2017, 01:21 PM
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3L 16V, 93 400E, 95 320TE, 95 E320, 98 S500
Quoted: 711 Post(s)
The boot doesn't fit inside the strut mount. The boot fits over the three fingers/prongs that are strapped on to the strut.
Sent from my XT1080 using Tapatalk
Jayare is online now
post #5 of 31 (permalink) Old 04-18-2017, 01:30 PM Thread Starter
Thank you, Jayare.
The boots top is not big enough to fit over the prongs. Do I have to take the strut to be fitted the boot??
valensf is offline
post #6 of 31 (permalink) Old 04-18-2017, 01:36 PM
LeftCoastGeek's Avatar
Date registered: Jul 2011
Vehicle: 1993 300CE Cabriolet (mine) ; 1994 E320 Wagon (wife's) ; 1990 Benz 300E 2.6 (spare)
Quoted: 1059 Post(s)
IIRC, the BOTTOM of the boot is clipped to the top of the strut body. the top of the boot is just floating.
LeftCoastGeek is offline
post #7 of 31 (permalink) Old 04-18-2017, 01:55 PM
Date registered: Mar 2010
Vehicle: 1989 560SEC, 1989 560SEL, 1995 E420
Quoted: 328 Post(s)
I believe the top of the boot is intended to fit over the two 'ears' shown in your photo. My boot had obvious stretch marks where it had been stretched over at one time. It is now a little too loose and doesn't stay in place as well.
luckymike is offline
post #8 of 31 (permalink) Old 04-18-2017, 03:18 PM Thread Starter
Thank you, LeftCoastGeek.
That is happening right now. But the bottom of the boot are a little big that partially come off and hitting the inside of tire! Then I thought the boot supposed to hang...
valensf is offline
post #9 of 31 (permalink) Old 04-18-2017, 03:29 PM Thread Starter
Thank you, luckymike.
Then like you said I've tried to fit the top of the boot over the ears of the bottom of the strut mount but too small to slide up.
Then I wonder the boot should be up side down from my current setting in my photo..it means top side of the boot is flare out....umm
valensf is offline
post #10 of 31 (permalink) Old 04-18-2017, 05:27 PM
Quoted: 328 Post(s)
Here's a rather poor pic I took of my car just now. It looks like the boot is supposed to fit around the flange at the base of the mount.
Name:	plum strut.jpg
