Hello Forum: I've owned 3 MB's and I've usually been able to figure out what I've needed to know by checking out the forums but I'm stumped on this latest issue. So, I've replaced the bulbs (pulled from my indy import parts place), cleaned the contacts and checked for any signs of wear on the wires. Fuses all seem fine.
The hazards work fine, front and back, steady blink and all are bright. All rear lights, brakes, signals & reverse are good during all functions with lights on and off.
Front lights are fine. With lights OFF, right front signal works fine but the bulb appears less bright. Left front (drivers) works but is brighter. With lights ON, right front signal works fine but is brighter. Left front (drivers) is less bright and you can barely see the filament flickering. It's very minute, such as it failed inspection.
Prior to buying new bulbs, the right side signal behaved the same way but the left side (drivers) signal would behave normally, front and back with lights off but when I turned on the lights the left rear blinked rapidly and front rapidly but you could barely see the filament flash and I got the dash "light" indicator telling me a bulb was out.
I swapped out the bulbs from the right to the left etc, with no difference.
Thanks,
Thanks,
