crank position sensors have been knonw to get temperature sensitive. get too hot, they stop working, engine stops working as the CPS provides both spark and injection timing on the HFM-SFI cars.
other things that might do that would include a flakey OVP, MAS or fuel pump relay.
...classic sign of a spent distributor and rotor. theyll start when cold and fail when hot until it wont start at all. id pull the cap off and have a look might be tune up time.
On the 91 I sold a while back,same issue,drove me nutso!, replaced and tested everything,then found a hairline crack on dist rotor mounting bracket, I could drive the car for 10-30 minutes,then it would stall and not restart until cooled, that crack would expand with heat and cause misalignment of rotor. fixed the problem and car was fine for 2 years,then sold it.
GUYS A MILLION APOLOGIES ITS AN M103 260E. SO RP suggestion stands.
My biggie I'd swear he told me its was a 280, but I am getting old and my hearing is going due to teenage girls screaming all day
ok, the m103 still has a CPS, its use for the ignition timing. it still could be a marginal OVP (overvoltage protection relay), or MAS/FRP (later 103's have a MAS combo relay, earlier ones have a separate fuel pump relay, either could cause the fuel pumps to stop, which stalls the car). On a M103, it also could be a overheated EZK. And yes, even possibly the flaky distributor that lowesguy mentioned above.
694.8K members
