» Site Navigation
» Other Sites
Old 11-21-2003, 12:24 PM   #1 (permalink)
eandytemp's Avatar
Date registered: Nov 2003
Vehicle: 1994 E420
1994 E420 Problems....Need Help
Problem: Will not down shift when you press down the accelerator. Hits the rev limiter at 4k rpm. Feels like there isn't any power at all. Seems like it's a four cylinder or something. It is also related to the cruise control as that appears to have stopped working.
Any help with this would greatly be appreciated.
Thank you,
Andy
2003 BMW R1100S BCR
2001 Honda XR50R The Kiddo's
1998 Honda CBR900RR
1997 Toyota 4Runner
1994 Mercedes Benz E420
1994 Honda XR250R
eandytemp is offline   Reply With Quote
Old 11-21-2003, 12:40 PM   #2 (permalink)
Vehicle: Benz 260E and others
You give us very little to work with. First you say it won't downshift then you say it hit...
You give us very little to work with. First you say it won't downshift then you say it hits the rev. limiter?? It won't downshift or upshift??
The cruise control should have no effect on the engine performance or transmission.
Give us more details.
jacks
JackD
1989 260E
2006 Mazda 5
1978 Corvette
1974 MGB
1998 Southwind Motorhome
1996 John Deer lawn mower tractor.
Jackd is offline   Reply With Quote
Old 11-21-2003, 01:16 PM   #3 (permalink)
eandytemp's Avatar
Vehicle: 1994 E420
Sorry. Well lets say you are driving at around 45 MPH, if you floor it, it just accelerat...
Sorry. Well lets say you are driving at around 45 MPH, if you floor it, it just accelerates from the current gear you are in. It will not downshift to a lower gear. It also does not feel like what a V8 should feel like.
The rev limiter problem I mentioned is also a problem. What I meant is if you shift down to 1st (B), or even 2nd gear manually and accelerate it will limit the rpm at 4k.
Also, from what I gather this is all leading to a malfunctioning part which also handles the cruise control.
Let me know if you need more information.
Thanks,
Andy
Old 11-21-2003, 03:33 PM   #4 (permalink)
The transmission should downshift when you depress the accelerator down to a certain posit...
The transmission should downshift when you depress the accelerator down to a certain position. If it does not, you probably need to adjust the automatic transmission shift cable.
Rev Limiter: The rev. limiter should not atctivate at 4,500RPM. There could be a problem with fuel supply at those speeds,or an ignition proble. You cat. converter could also be the cause.
jackd
Old 11-21-2003, 06:43 PM   #5 (permalink)
Vehicle: 300TE
Stretching Things.
Something to check, as it sounds like rental cars I used to get.....
Is the throttle fully open when you press all the way dowm in the gas pedal...???
If it is out of adjustment or stretched (how would that happen..??) you would get the same symptoms.
Certainly the cheapest thing to check, you just need an assistant or a broom handle.
Ian P.
Ian P. is offline   Reply With Quote
Old 11-23-2003, 12:10 PM   #6 (permalink)
zeronero's Avatar
Date registered: May 2003
Vehicle: Mercedes-Benz 400E
Your transmission downshift problem can be traced to a broken kick down switch or a need...
Your transmission downshift problem can be traced to a broken kick down switch or a needed adjustment to the transmission adjustment cable. My car used to do the same thing by not downshifting soon enough. I adjusted the cable almost to the extreme of easily shifting and now if I just tap on the gas on the freeway it downshifts.
1992 Mercedes-Benz 400E
zeronero is offline   Reply With Quote
Old 11-23-2003, 01:42 PM   #7 (permalink)
janos_z's Avatar
Vehicle: 1989 560 SEL, 1994 E320 wagon, 2007 C230
as i've posted before, my 400E is reluctant to downshift, too. can you post a diagram of...
as i've posted before, my 400E is reluctant to downshift, too. can you post a diagram of where to find and adjust this transmission cable? i think it's worth checking into. thanks!
Janos
Current:
-1989 560SEL
Past:
-2007 C230
-1994 E320 wagon
-1993 400E
janos_z is offline   Reply With Quote
