Old 11-12-2003, 09:36 AM   #1 (permalink)
benzpeice's Avatar
Date registered: Nov 2003
Vehicle: '93 300E 2.8L
When connecting euro lights....
Hey guys
I'm putting in my new lights that came in today. Taking out the old assembly was easy enough but now i'm at the point where the euro light assembly needs a 5 pin connector and i have a 4 pin from the old setup.
the new assembly came with a new connector peice and 10 new chrome pins (5 for each).
I noted where the old wires/colors went (white/green to 1, red to 2 etc...)
Where do I get the 5th wire from? I think they're for my foglights since when I tried to connect it with only 4 wires, the lights and highbeams worked, but no foglight.
Someone help!?
benzpeice .::. 300E 2.8
benzpeice is offline   Reply With Quote
Old 11-12-2003, 11:14 AM   #2 (permalink)
Vehicle: Benz 260E and others
You need to get a new 5 pins connector from your friendly local Mercedes dealer. They are ...
You need to get a new 5 pins connector from your friendly local Mercedes dealer. They are only a few $$.
That's the only way I know to have those lights function properly, unless you want to go to the spicing/cuttin/welding new connections.
jackd
JackD
1989 260E
2006 Mazda 5
1978 Corvette
1974 MGB
1998 Southwind Motorhome
1996 John Deer lawn mower tractor.
Jackd is offline   Reply With Quote
Old 11-12-2003, 01:26 PM   #3 (permalink)
BenzWorld W124 Host
Tubs300E's Avatar
Date registered: May 2003
Vehicle: 1993 300E 3.2L 24V
I just used the old wiring, pulled it out of the old units ran it in the new ones, that wa...
I just used the old wiring, pulled it out of the old units ran it in the new ones, that way I figure the only thing I'm changing is cosmetic, no real electrical mishaps from new wiring.
-Tubs
W124 Forum Host
1993 Mercedes-Benz 300E Arctic White over Palamino Leather
W124.032 Chassis M104.992 24V Engine
217 Horsepower @5500RPM
229lbs-ft Torque @3750RPM
Aftermarket Modifications
-TYC Euro-Spec Headlamps
-DEPO Clear turn signal indicators
-Kenwood KDC-217S CD Player AM/FM Tuner Headunit
-Chrome Exhaust Tips
-Auxiliary fog lights and driving lights
-Tinted windows: 22.7% on the back 5 and 33% on the front 2
Tubs300E is offline   Reply With Quote
Old 11-12-2003, 02:56 PM   #4 (permalink)
benzpeice's Avatar
hows it look?
Old 11-12-2003, 03:01 PM   #5 (permalink)
benzpeice's Avatar
:D
Old 11-14-2003, 06:39 PM   #6 (permalink)
benzpeice's Avatar
Just for Reference - 5th Connection
What I did to take up the 5th Connector.
I spliced a wire from the parking light to the 5th connector that was open and made it so that the little Peanut (City) Bulb goes on with my side markers (in the first turn position on the dial).
Voila. I didn't think that I would be able to add a city light to my joint, but it turns out that I did and it looks very nice.
Old 11-14-2003, 07:46 PM   #7 (permalink)
Chupper's Avatar
Date registered: Sep 2002
Vehicle: 1986 300E
Send a message via AIM to Chupper
That is tight. I need to connect my city light. ...
That is tight.
Chupper is offline   Reply With Quote
Old 11-14-2003, 07:52 PM   #8 (permalink)
salamanca's Avatar
Vehicle: 1988 260 E 128,000
Them lights are off-the-chain![;)]...
'88 260 E
"How many legs does a dog have if you call the tail a leg? Four. Calling a tail a leg doesn't make it a leg."
salamanca is offline   Reply With Quote
Old 11-15-2003, 03:53 PM   #9 (permalink)
Chupper's Avatar
Vehicle: 1986 300E
What bulb do you use for the city light?...
Old 11-18-2003, 08:55 AM   #10 (permalink)
benzpeice's Avatar
Chuppz
The headlight assembly I received has a space for a small Peanut bulb above the H4 casing. I bought a set of PIAA Peanut bulbs and they worked perfectly.
When I was putting the assembly in, and I saw the hole for the bulb - both my friend and I started jizzing ourselves. He was all "I DIDN'T KNOW MERCEDES DID THAT!)#&(*!@#" so now he's gotta get those Angel Eyes for his 7 Series to compete.
As I said I wired the 5th connection from the turning signal corners and when I have the knob in the 2nd of 3 positions the city lights come on.
