The headlight assembly I received has a space for a small Peanut bulb above the H4 casing. I bought a set of PIAA Peanut bulbs and they worked perfectly.
When I was putting the assembly in, and I saw the hole for the bulb - both my friend and I started jizzing ourselves. He was all "I DIDN'T KNOW MERCEDES DID THAT!)#&(*!@#" so now he's gotta get those Angel Eyes for his 7 Series to compete.
As I said I wired the 5th connection from the turning signal corners and when I have the knob in the 2nd of 3 positions the city lights come on.
Do you have pix of the headlamp assembly, including the space for the "Peanut" bulb ??
Just to clarify -- when you have the knob in the "park lamp" position, the "city lights" turn on ?? Headlamps off, city lamps (like DRL) are on ??
No I didn't take pictures of the assembly although next time I mess with it I will take ...
No I didn't take pictures of the assembly although next time I mess with it I will take pics.
In the Park Lamp position (whatever its called when its just one click to the right) The parking lights and city lights come on. If you pull it out the fogs come on. With it off, everything is off.
Where did you get the "peanut" bulb from?
I would also be interested in getting this fe...
I would also be interested in getting this feature attached a working.
-Tubs
__________________ W124 Forum Host
1993 Mercedes-Benz 300E Arctic White over Palamino Leather
W124.032 Chassis M104.992 24V Engine
217 Horsepower @5500RPM
229lbs-ft Torque @3750RPM
Aftermarket Modifications
-TYC Euro-Spec Headlamps
-DEPO Clear turn signal indicators
-Kenwood KDC-217S CD Player AM/FM Tuner Headunit
-Chrome Exhaust Tips
-Auxiliary fog lights and driving lights
-Tinted windows: 22.7% on the back 5 and 33% on the front 2
