» Site Navigation
» Other Sites
Old 08-14-2003, 12:53 AM   #1 (permalink)
kggkgg's Avatar
Date registered: Aug 2003
Vehicle: 95 E300D
Learning about a/c
can anyone point me in the direction of some good reading on auto a/c , in particular that fitted to 124's (early 90's factory fitted) but otherwise just generally. I'm new to dealing with problems in this area and seem to be wasting money on so called experts so have decided to go the trusted route of DIY but need to gen up.
Also are there any pictures of the physical layout of a/c in w124s to help me get orientated.
I'm asking on the US site since I reckoned you guys will have loads more gen on this subject.
Keith
Keith
95 E300D Wagon 170k miles
ex - 94 SL320 58k miles
kggkgg is offline   Reply With Quote
Old 08-14-2003, 11:59 PM   #2 (permalink)
Vehicle: '87 300D-Turbo
...good question. I, unfortunately am also in this quandry - for three years now. An...
...good question.
I, unfortunately am also in this quandry - for three years now. Anybody have an answer/suggestions/advice?
My A/C has not blown cold for three years now, and I have gotten numerous estimates - all expensive (possible leak; dye to trace leak; compressor; pump; etc...) But how do you actually determine whats wrong (starting simple)?
I did a mjor service yesterday (30k service on '87 300D-Turbo w/ 150k) and all of a sudden the A/C is blowing cooler (not COLD, but cooler), why is this?
KHULE-1 is offline   Reply With Quote
Old 08-15-2003, 01:38 PM   #3 (permalink)
Vehicle: 95 E320 Cabriolet
You may want to check aircondition.com. Though I was quite comfortable doing all kinds of...
You may want to check aircondition.com. Though I was quite comfortable doing all kinds of wrenching on cars, a/c systems were always a mystery until I started surfing that site. After spending many hours amassing bits of information from the experts in the postings, I'm now quite comfortable that I can do a better job than the local shop.
Diagnosing and repairing your own a/c systems is quite rewarding both personally and financially.
This message written with 100% recycled electrons.
Kestas is offline   Reply With Quote
Old 08-17-2003, 03:58 AM   #4 (permalink)
marek's Avatar
Vehicle: C140 S420Coupe
typical problem is the radiator! check bottom corners, there may be some oil. then you nee...
typical problem is the radiator! check bottom corners, there may be some oil. then you need new radiator! and other typical problem is coolant's low pressure.
marek is offline   Reply With Quote
