Old 07-11-2003, 09:15 PM   #1 (permalink)
Date registered: Jul 2003
Engine problem w/ '94 E500
My '94 E500 with 69,000 miles ran poorly today immediately after I filled the tank with gas. It has happened before, but I can't specifically recall the last time. Post fill up today it had rough idle, barely accelerated and what little acceleration it mustered was uneven, and the exhaust smelled like smoke bomb (sulfur?) (exhaust color was normal). After about 15 minutes of running/idling the problem worked itself out - I'm positive it is not a gas quality problem. Any thoughts on what is causing this problem? Thanks in advance.
SSmithMB is offline   Reply With Quote
Old 07-12-2003, 12:06 AM   #2 (permalink)
Date registered: Jan 2003
Vehicle: 1989 300E
sorry cant help ya on this one, my advice, get it checked as soon as possible. ...
<img src="http://img47.imageshack.us/img47/3240/sig4my3.jpg">
briby is offline   Reply With Quote
Old 07-14-2003, 07:56 AM   #3 (permalink)
Vehicle: 95 E320 Cabriolet
More than once I've gotten water in fuel. This resulted in horrible idling and driveabili...
More than once I've gotten water in fuel. This resulted in horrible idling and driveability -- but no sulfur smell.
Water in gas is typically easy to diagnose. Break into the fuel line and pump out a quantity of gasoline into a clear container. The water settles to the bottom.
This message written with 100% recycled electrons.
Kestas is offline   Reply With Quote
Old 07-14-2003, 04:33 PM   #4 (permalink)
Vehicle: Benz 260E and others
How can a guy with an e500 complain about poor acceleration. If this happens again, just ...
If this happens again, just imagine you had a 260E for a few minutes.
I can write a book about poor acceleration, you can't.
More Seriously....
I had a similar problem with a 1994 Volvo 850Turbo" I know, I know it is not a e500. The problem was some kind of deposit at the bottom of the fuel tank. Every time I fueled, those deposits obstructed the fuel pick-up tube. I had the tanks cleaned out and which solved the problem.
JackD
260E
JackD
1989 260E
2006 Mazda 5
1978 Corvette
1974 MGB
1998 Southwind Motorhome
1996 John Deer lawn mower tractor.
Jackd is offline   Reply With Quote
