» Site Navigation
» Other Sites
Old 07-11-2003, 01:03 AM   #1 (permalink)
Team PMS Racing's Avatar
Date registered: Apr 2003
Vehicle: 91 300 E
Radio, speed control
Does anyone know how the volume increase function works on the Becker?
Is there a tach signal?
If so, can that tach signal be removed?
Does this affect the power supply?
Reason I ask is i had a radio installed and there is a noise that seem to affect the radio at certain speeds.
Team PMS..."We win once a month, period."
Team PMS Racing is offline   Reply With Quote
Old 07-12-2003, 04:48 PM   #2 (permalink)
SHIFT_diesel's Avatar
Vehicle: 1987 300D Turbo
I might be wrong, but it could just be alternator noise. I think its caused because as y...
I might be wrong, but it could just be alternator noise. I think its caused because as you speed up, your alternator also regenerates more power. Thus, it increases the voltage and gets some to the speakers, causing it to have a buzz or certain noise. I believe a inductor or a capicator will fix it. I'm not sure which one, but pretty sure its the inductor. Can anyone else correct me if i'm wrong? Thanks.
Jason Mak
1974 280 (W114)
1979 300SD (W116)
1983 300D Turbo (W123)
1987 300D Turbo (W124)
www.maxilube.com
SHIFT_diesel is offline   Reply With Quote
Old 07-12-2003, 11:54 PM   #3 (permalink)
Vehicle: 91 300 E
Shift_D I have an update. It was the factory amp that was giving the problem. Once it...
Shift_D
I have an update. It was the factory amp that was giving the problem. Once it was removed from the "mix", things started sounding real good. I have not had a problem since the repair.
As per your suggestion about alt. noise....that is usually a whine that is present all the time. This noise came and went, it seemed to only appear when the car hit 40 and 50 mph. This is why I thought it was some sort of tach signal.
But thanks for the tip anyway. I hope this helps someone in the future to NOT go through the heart ache I did.
Old 07-13-2003, 10:39 PM   #4 (permalink)
No probs. Just a lil suggestion of something i learned from school [:O]...
Old 07-13-2003, 10:42 PM   #5 (permalink)
BenzWorld W124 Host
Tubs300E's Avatar
Date registered: May 2003
Vehicle: 1993 300E 3.2L 24V
I get that on the AM band when no station is present. It buzzes like a bad Civic with a ...
I get that on the AM band when no station is present. It buzzes like a bad Civic with a fart pipe. Me and amy friends like to blast the radio on that and play Ricer.
-Tubs
W124 Forum Host
1993 Mercedes-Benz 300E Arctic White over Palamino Leather
W124.032 Chassis M104.992 24V Engine
217 Horsepower @5500RPM
229lbs-ft Torque @3750RPM
Aftermarket Modifications
-TYC Euro-Spec Headlamps
-DEPO Clear turn signal indicators
-Kenwood KDC-217S CD Player AM/FM Tuner Headunit
-Chrome Exhaust Tips
-Auxiliary fog lights and driving lights
-Tinted windows: 22.7% on the back 5 and 33% on the front 2
Tubs300E is offline   Reply With Quote
