» Site Navigation
» Other Sites
Old 06-25-2003, 08:12 AM   #1 (permalink)
Team PMS Racing's Avatar
Date registered: Apr 2003
Vehicle: 91 300 E
Seat removal
Ok, this is a very specific question for anyone who has removed a driver's seat (My car is a 91 300 E):
What tools are best for this proceedure? For example, lenth of extention and flexible joint if any.
When I push the down botton for the rear of the seat, only the left side goes down. The seat twists in a manner that can only be discribed as fully disturbing.
Now I'm Not talking about where your back rests, I mean the left rear corner where my butt goes. I'm hoping it is just a simple fix like a wire is pinched or unpluged. I can't get my puggy fingers in there to check with out removing the seat.
And how in the heck do I get to the bolts on the right side which sandwich the consul?
Any help will be most appreciated. And BTW, if this thread looks kinda familar, well, it is. But as par usual, the thread took a turn in a strange way and has nothing to do with seats anymore.(grin)
Thanks all
Team PMS..."We win once a month, period."
Team PMS Racing is offline   Reply With Quote
Old 06-25-2003, 09:10 PM   #2 (permalink)
Vehicle: 91 300 E
I guess everyone is busy with the flame match that is going on in another post. I'm gon...
I guess everyone is busy with the flame match that is going on in another post. I'm gonna just keep out of that. Hopefully someone will take pity on my seat problem and help me try to shed some light.
Here's what I know so far:
Power is getting to the plug on the right side motor for rear base of the seat up and down. There seems to be some module tucked up in there. I'm assuming that it is this module that is the problem. Does anyone have any thoughts on this module?
Old 06-25-2003, 09:40 PM   #3 (permalink)
BenzWorld Senior Forum Host & Managing Editor
Drew's Avatar
Date registered: Jul 2002
Vehicle: '00 ML320 Elegance
No flame wars...
At least not when I'm around. [}:)]
Regarding the seat, I can't speak for your car, however for the ML or the W203 C-class, in order to unbolt the seat from the floor, what they seem to do is to move the seat all of the way forward. There are then a couple of bolts per side, at the base of the seat frame or in the seat rail track, which then have to be loosened. After that, move the seat back in order to access the front bolts.
The module that you are referring to is most likely the seat memory module I <i>think</i>. I'm not certain if those were incoporated into the door, as the newer cars now are.
Good luck! [:)][8]
BenzWorld.org Senior Forum Host & Lighting guru
MB OEM Bi-Xenons with E-code modification, custom-cut StonGard Light protection film, Hella FF100 & FF200 foglamps with wireless switch, Hella dual tone air horns, Bosch ParkPilot reverse warning system, Tomar Hide-a-way emergency vehicle front strobes, integrated reverse warning strobe lights with wireless switch, chrome handle accent strips and chrome door handle shells, AMG chrome ringed gauges, Euro M-class footwell net, 3M reverse safety fresnel lens, Euro blindspot interior mirrors, MCS GPS nav system, chrome headlamp rings, chrome fender signal rings, Personalised designo interior, Drinkholders.com burl walnut ML cupholder, hardwired Valentine One radar detector, LED-based front and rear LED footwell ambience lighting, illuminated MB door sills for each door, Clear acrylic hood deflector, Weathertech window deflectors, EGR rear deflector, 3M Scotchtint 50% tint on front windows, 3M Scotchtint 20% tint on top 4" of windshield, driver side mounted fire extinguisher, chrome tailgate handle, "Elegance" side badges, '02 Bose tweeters and sail panels, '02+ tailgate filler panel, AMG silver painted/chrome accented front grill, silver painted lower bumper grill, MB OEM Style 1 chrome sidesteps & chrome brushguard with skidplate, MB OEM front mudflaps & aftermarket flexible rear mudflaps, chrome door rubstrips, MB Lamella Skyview roof deflector, MB accessory roof crossbars & ski rack, AMG oval exhaust tip, 17" EVO II Sport package wheels & Michelin Cross Terrains, DesignTech halogen backup bulbs, Formymercedes.com 20" LED brake strip with Flash alert, 6" 3rd brake lamp LED strip, High-intensity LED taillamps, front and rear LED amber turn signals, HyperWhite LED city lamps
Drew is offline   Reply With Quote
Old 06-25-2003, 10:21 PM   #4 (permalink)
Vehicle: 260e
Switch?
Sure it's not the switch, they get carbon coated and don't work as well if they were clean. I'd put in a switch that works to test before you go and pull the seat.
Chris E. is offline   Reply With Quote
Old 06-25-2003, 10:41 PM   #5 (permalink)
Vehicle: 91 300 E
My friend is a Cadi mechanic and he said there was power from the switch when he tested ...
My friend is a Cadi mechanic and he said there was power from the switch when he tested it. The power got lost at the modual to the motor.
I tried to find something like a price for this modual but had no success. Aditioanlly, the CD's had no mention of the modual. It did point to another part on the cd, but i could not find it. Does anyone know the price of the modual or atleast it's name?
Thanks for the replies.
Old 06-25-2003, 11:28 PM   #6 (permalink)
Drew's Avatar
Have a picture?...
If you do, or better yet a part number, I might be able to help you to get a price on it.
Old 06-25-2003, 11:44 PM   #7 (permalink)
Vehicle: 260e
module
The part # should be on the module itself. I would go find a recycler/junkyard and find a replacement module. Just make sure it's the module you want and not the switch. You don't want to buy unecessary parts for this car they are quite expensive.
HTH
Old 06-26-2003, 12:21 AM   #8 (permalink)
Vehicle: 91 300 E
Well I guess my next step will be to pull the seat and look for a part number. There ar...
Well I guess my next step will be to pull the seat and look for a part number. There are a few reasons why I don't believe it is the switch.
1. The seat does go up and down on the left side, but not the right. The switch should move both motors in unison so I believe it would be one contact for two motors. Otherwise, people would have lopsided butts because they did not hit the switch corectly and one side would move first throwing off the whole seat.
2. The wiring appears to go into a powerstrip which is making the test light go on when the button is pushed. So the switch must be working.
I do believe I am getting close to the solution though.
3. The wiring into the module has power and is activily showing switch signal. However, between the module and the motor there is an open circut.
If I had a wiring diagram, I'm sure there is a way to elinate the module which most likely is for the seat memory. But I think I would not want to rig my Mercedes.
