» Site Navigation
» Other Sites
Old 05-13-2003, 08:48 AM   #1 (permalink)
SethMac86
Date registered: Apr 2003
Vehicle: 95 E320
history on W124
were can i get the history of these cars? i know about the late model ones but earlyer than that i am clueless like on the 300E 400E's, like the specs and dates they were built, like a website or just some info would help
thanks
95' E 320-current ride
94' E500(Gone)
88' 300SEL(Gone)
SethMac86 is offline   Reply With Quote
Old 05-13-2003, 08:54 AM   #2 (permalink)
Team PMS Racing
Team PMS Racing's Avatar
Vehicle: 91 300 E
Hey Seth, I found this a while back. I checked the link and it still works. It is n...
Hey Seth,
I found this a while back. I checked the link and it still works. It is not very techie but has some clean pix and some nice words about the later models.
Hope you like it.
Big Ed http://www.mercedesshop.com/300e.htm
Team PMS..."We win once a month, period."
Team PMS Racing is offline   Reply With Quote
Old 05-13-2003, 01:30 PM   #3 (permalink)
SethMac86
Vehicle: 95 E320
yea but what about
i read somewhere that the 500E was made in the porsche factory? is this true and it had porsche parts or something? and was the 500E comparable to a then AMG i guess? just wondering
Old 05-13-2003, 04:38 PM   #4 (permalink)
abarton@yahoo.com
abarton@yahoo.com's Avatar
Vehicle: 300 TE 24 Sportline
Yep
The 500E was built I believe by Porsche (both Porsche and Merc are based in Stutgart.
AMG used to be an indipendant tuner. They were bought by Merc as an antagonist to BMW M power.
The first part official result of this buy out was the European W124 sportline's that were fitted with their suspension, seats and steering at AMG's factory.
This was prior to the W124 320E AMG. that was a bored out 300E-24v M104.
I don;t have any of the above for sure but its what I've heard.
1990 300TE-24v
Factory fitted Sportline
No Cat, no airbags.
Full leather, electric seats.
Nearly 240bhp on Leaded. 0-60 mid 7 seconds
13 years old and still kicking BMW butt !!
abarton@yahoo.com is offline   Reply With Quote
Old 05-13-2003, 04:46 PM   #5 (permalink)
jzaroh
jzaroh's Avatar
Date registered: May 2003
The 400E, too. I think the entire M119 engine was designed by Porsche. It had heft...
jzaroh is offline   Reply With Quote
Old 05-13-2003, 06:31 PM   #6 (permalink)
Chupper
Chupper's Avatar
Date registered: Sep 2002
Vehicle: 1986 300E
Send a message via AIM to Chupper
500E's and E500's (early model E500) did have engines that were designed, built, and insta...
500E's and E500's (early model E500) did have engines that were designed, built, and installed by Porsche.
Cool isn't it [8D]!
Chupper is offline   Reply With Quote
Old 05-14-2003, 07:48 AM   #7 (permalink)
y2kimmel
Not built by Porsche
The engine in the 500E and E500 were not built by Porsche. They were Mercedes 5.0L V-8s from the SL and S500 modified to fit into the W124's more constricted engine bay. Porsche helped Mercedes by using their facility to construct the autos, and doing some of the design mods to accomodate the bigger engine and beefier suspension.
y2kimmel is offline   Reply With Quote
Old 05-14-2003, 12:55 PM   #8 (permalink)
Chupper
Chupper's Avatar
Vehicle: 1986 300E
I was wrong
Some correct information regarding who built what:
Each 500E started life at the Rossle-Bau plant where the basic body shell was completed, including doors, trunk, and hood, and then transported on special trucks to the Mercedes Sindelfingen plant across town. There, the body was corrosion-proofed and painted, giving it the full measure of rust protection and allowing customers to choose from the entire palette of Mercedes colors. Then each 500E went back to the Porsche plant for more assembly. Engines, transmissions, and other major mechanicals were assembled by Mercedes and shipped to Porsche for installation. Then another trip across town, back to Mercedes, where each 500E received a final inspection before delivery or export. On average, it took 18 days to build each 500E, much of which was consumed by transportation time.
Porsche's modifications to the original 300E included splaying-out and reinforcing the frame rails, widening the driveshaft tunnel, modifying the front axle crossmember and other engine bay components to accept the 5-liter 326-hp V8 engine that was also specified for the 500SL at that time and weighed 32 kg more than the 300E's inline-6 engine. The heavy duty battery was moved to the trunk to achieve an ideal 50:50 weight balance with two occupants and 80 kg of luggage aboard. 500SL-sourced wishbone suspension pieces and steering linkages were reinforced to accomodate the 500E's increased weight. The 500E stands nearly 2.5 cm lower than the 300E due to shorter and stiffer springs with plastic buffers and gas pressurized shock absorbers with internal damping springs. A hydraulic self-leveling suspension is standard equipment. 11.8-inch vented disc brakes in the front were sourced from the 300CE, and the 10.9-inch vented rear discs were the same as the 500SL. Wider wheels and tires resulted in a 37 mm wider track at the front and 38 mm at the back. The wheel well fenders were flared out to better accomodate the extra width.
Old 05-14-2003, 01:13 PM   #9 (permalink)
abarton@yahoo.com
Think I'll stick to the 6cyl
Would love a 500E but the 300-24 is bad enough on fuel
