» Site Navigation
» Other Sites
Old 05-13-2003, 02:29 AM   #1 (permalink)
benz_ride
benz_ride's Avatar
Date registered: May 2003
Vehicle: 300 E 24V 1989
Problem with my AC Temperature !!!
I'm very headache with my temperature. It always going up to 110 C. when traffic. But if out from traffic, the temperature going normal 85 Celcius.
Anyway I already changed my A/C condenser, Fan clutch, Water Pump, Thermostat and all the rubber pipe from radiator to engine. But the temperature still hot. What I must do with this problem ? somebody can help me? anyone have diagram for cooling system and climate system ? Please attach to my email @ benz_ride@hotmail.com . Thanks.
benz_ride
W124 300E 24V '89
Audio : Alpine 7998, Power Orion 800.4, Lightning Capasitor, EQT, Speaker MBQuart, Sub-woofer Rockford 12" 2 pieces.
Rims : AMG 18x8, Falken 225/40/18.
Springs : Eibach lower springs.
benz_ride is offline   Reply With Quote
Old 05-14-2003, 11:14 AM   #2 (permalink)
flyboyike
flyboyike's Avatar
Vehicle: '79 280E
[:)]I would suggest a complete radiator flush, if that doesn't help recore or replace th...
[:)]I would suggest a complete radiator flush, if that doesn't help recore or replace the radiator. What you are describing sounds like poor coolant circulation and since you have replaced everything else the radiator seems the only remaining suspect
flyboyike is offline   Reply With Quote
Old 05-14-2003, 12:30 PM   #3 (permalink)
Ian P.
Vehicle: 300TE
Hot Topic...
You didn't mention if the electric fan was working properly.
If it isn't, check the fuse first (yep...start with the easy stuff) as they do go poof!! on ocassion.
If the fan is working, the thermostat is not sticking or restricting the flow and the other stuff is all first rate.....maybe you don't have a problem.
Try checking the temperature sensor. It may be reading a bit high.
Ian P.
Ian P. is offline   Reply With Quote
Old 05-15-2003, 08:56 AM   #4 (permalink)
benz_ride
benz_ride's Avatar
Problem with AC Temperature
Electric fan, thermostat and fuse already checked, it all good.
I'll check on AC temperature Sensor.
Do somebody have another opinion for this problem ?
