» Site Navigation
» Other Sites
Old 01-26-2003, 12:03 PM   #1 (permalink)
Twitch's Avatar
Vehicle: 1988 560SEL
1990 300CE 24v
Hey, I just found this 1990 300CE 24v for sale and I would like to know some specs about it.
1.Horsepower(217?) and Torque
2.Engine(3.0 Inline 6 DOHC?)
3.What can expect for a performance point of view (acceleration, top speed??)
4.Maintenance cost?
Thanks
1990 Mazda MPV
1988 Mercedes-Benz 560SEL 260k KM
1981 Mercedes-Benz 300SD 255k KM (died 11/11/2002)
Like cars? Check out my site
http://twitch.zonehere.com
And you're watching http://www.PCMTL.com Ep #21,22: TeamSCP Jarry Parc
Twitch is offline   Reply With Quote
Old 01-26-2003, 01:00 PM   #2 (permalink)
heckflosse's Avatar
Specs for the Euro 300-24 non catalyst with 5sp Auto; 231bhp @ 6300rpm 200lb.ft tor...
231bhp @ 6300rpm
200lb.ft torque @ 4600rpm
2962cc Inline 6 DOHC
Max Speed = 146mph
0-60 = 7.8 secs
Standing 1/4 mile = 16 secs
File Type: jpg W124_50046.jpg (0, 7 views)
heckflosse is offline   Reply With Quote
Old 01-26-2003, 08:12 PM   #3 (permalink)
Twitch's Avatar
Variable Valve Timing
I've heard that the 1990 300CE 24v had the variable valve timing technology. Is it true??
Old 01-26-2003, 08:40 PM   #4 (permalink)
BenzWorld R170 SLK Host
Periokid's Avatar
Date registered: Jul 2002
Vehicle: had an SLK32
Yes it is true...
The intake cam has variable timing.
Go to http://www.slk32.com for great SLK info!
http://www.leonoff.net
Periokid is offline   Reply With Quote
Old 01-27-2003, 06:29 AM   #5 (permalink)
Date registered: Jan 2003
Vehicle: 190 2.3-16
M104 engine
The 90 up 300CE (W124) is equipped w/ an Mercedes Benz M104.980 engine which has an output listed @ 228hp. All Mercedes M104 engines from 90-97 utilize variable valve timing.
The M104 engine is plauged in that it leaks like a Harely. [;)][:o)]
Pat Bartholow
Potomac German Auto
800-831-7686 ext#206
190E 2.3-16 w/ too many mods to list.
Black & Red sportline interior !!!
Potomac Pat is offline   Reply With Quote
Old 01-27-2003, 11:15 AM   #6 (permalink)
abarton@yahoo.com's Avatar
Vehicle: 300 TE 24 Sportline
Re: M104 engine
Its 228 bhp in the US with Catalytic Converter and crap petrol. Here in Europe we get more power as no cat on the early ones and if you run it on 98 octane 4 star leaded (still available in some countries at a few stations) we get nearer 240bhp
The VVT is hydralic and powered by the engine oil so you know when your running low on oil before the light comes on as you start to loose a bit of mid-range.
Just had the head on mine done. Prior to gasket job, was using 1litre / 1000 miles on an engine with 150,000 miles. It was leaking from the only place it realy does, the front right hand side above the alternator (generator in US?).
Since head job I've done 2,000 miles, and used no oil at all. None..zip...bugger all... not an ounce, litre, pint or milligramme.
1990 300TE-24v
Factory fitted Sportline
No Cat, no airbags.
Full leather, electric seats.
Nearly 240bhp on Leaded. 0-60 mid 7 seconds
13 years old and still kicking BMW butt !!
abarton@yahoo.com is offline   Reply With Quote
Old 01-27-2003, 03:14 PM   #7 (permalink)
Twitch's Avatar
So the 1990 300CE 24v US version is only available with that 228HP engine? Why do I see d...
So the 1990 300CE 24v US version is only available with that 228HP engine? Why do I see different engine specs on every site?(like some say 217hp)
Old 01-28-2003, 07:03 AM   #8 (permalink)
Periokid's Avatar
The USA engine of 1990-1992 is.....
217hp
198 lb ft torque
Old 01-28-2003, 12:34 PM   #9 (permalink)
heckflosse's Avatar
In the book I've got the specs listed are; 300E-24v RUF (Euro) = 231bhp & 200lb.ft to...
300E-24v RUF (Euro) = 231bhp & 200lb.ft torque
300E-24v KAT (USA) = 220bhp & 195lb.ft torque
