» Site Navigation
» Other Sites
Old 07-30-2002, 04:37 PM   #11 (permalink)
Date registered: Dec 1998
Re: Antilock warning light
<ul><hr><i>Originally posted by Ian</i><br><br><b>Greg,<br> <br> Replace your Overvoltage Regulator Relay, (it sits behind the battery). This is the most common part that mercedes dealers sell. Once it begins to fail, it causes the ABS light to illuminate even when the voltage has not dropped.</b><hr></ul><br> I had similar problems today after jump-starting my low-battery 300CE. How can you tell if this relay has failed ??<br>
Old 07-30-2002, 04:37 PM   #12 (permalink)
Old 08-09-2002, 07:13 PM   #13 (permalink)
Manuel NSX1164's Avatar
Vehicle: 300CE, NSX, Miata
How do you diagnose this?
What is the Part # for this ??
Thanks -- Manuel
Manuel C - Chicago IL
93 320CE Sportline : basic mods
93 Acura NSX : track-prepared
97 Mazda Miata : stock for now []
Manuel NSX1164 is offline   Reply With Quote
Old 08-12-2002, 11:00 AM   #14 (permalink)
pricing for over-voltage regulation/protection relay
Part # 000 540 67 45
Its available for $53 (wholesale pricing) from Rusty [rusty@mbz.org].
Old 08-13-2002, 12:11 PM   #15 (permalink)
problem fixed -- thanks MercedesShop Forums
Got the info from Merecedes Shop Forums ( http://www.mercedesshop.com ). Turns out the FUSE (blue 15A) atop the OVP was all that was bad.
On a 300CE, the OVP is located under the black plastic cover behind the battery. The OVP is a beige-colored relay with a clear plastic flip top fuse cover.
Picture of my OVP below
