Transmission - slow start on 1st gear - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-25-2002, 05:14 AM Thread Starter
Date registered: Dec 1998
Quoted: 2 Post(s)
Hi all,<br> my 91 300E 4Matic starts really slow on first gear almost feel like I have brakes on and pushing the acc. pedal. Am I going to need new tranny? Or is this normal? Does not seem to have those quick acceleration on start.<br> Thanks for your help.
Guest (MBNZ) is offline
post #2 of 5 (permalink) Old 06-25-2002, 07:39 PM Thread Starter
Quoted: 2 Post(s)
Re: Transmission - slow start on 1st gear
I have a 90 300TE 4-Matic which does the same thing only when the engine is really hot. Sometime it gets to the point that I have to push the pedal real hard and the car will take off gradually and then 'vroom'. I feel like something is blocking the fuel line that resists the fuel intake.
post #3 of 5 (permalink) Old 06-26-2002, 05:17 AM Thread Starter
Quoted: 2 Post(s)
There has to be a reason for this if it was meant to do this. Other wise, what would be causing this?
post #4 of 5 (permalink) Old 06-27-2002, 09:13 PM Thread Starter
Quoted: 2 Post(s)
I have a 86 300E. The transmission on my car starts out in 2nd gear. If you push the peddel to the floor the car will down shift into first. I do not know if your 4matic has this feature. On the newer modles the transmission starts out in first gear. Look at some of the older post on this page I have seen some on this in the past.<br> <br> If you put the shifter in the 2nd while stoped the transmission will shift into first. My car does not have a position on the shifter for first.
post #5 of 5 (permalink) Old 06-28-2002, 05:17 AM Thread Starter
Quoted: 2 Post(s)
Thanks for the tip. I think you are right. It seems starting at 2nd gear and when I depress the pedal, it down shifts to first. I wonder why they have designed it this way.....
