Old 06-21-2002, 01:21 PM   #1 (permalink)
Date registered: Dec 1998
Tune Up
I am planning on doing tune up this weekend. I am planning on changing spark plugs (Bosch Platinum 4+), rotor, distributor cap. Do you need to change the spark plug wires also? Wire looks okay to me. What else is involved in regular tune up? Fuel filter?
Old 06-21-2002, 04:16 PM   #2 (permalink)
Re: Tune Up
Don't change the cap & rotor unless they are bad. Ditto for the plug wires. That is unless you don't mind spending $200-$400 for those 3 parts! They typically last 100-150kmi. If they actually are bad, then you should replace them, obviously. <br> <br> Yes, fuel filters are a good idea too, along with your other regular maintenance (oil every 5k, tranny every 30k, power steering fluid & filter every 30-60k, brake fluid every 2 years, brake hoses every 5-7 years, coolant every 2-3 years, etc)
Old 06-21-2002, 08:49 PM   #3 (permalink)
Re: Tune Up
How do you change a fuel filter? Thanks
Old 06-26-2002, 01:12 PM   #4 (permalink)
Re: Getting Wired
While you have things apart, it is a good idea to remove all the plug wires just to inspect them. Look for burned, broken or worn spots.<br> Also check the wires and connectors for resistance (write the numbers down...) they should all be the same. Probably in the 5K ohm range.<br> Dave is right (of course..) if it ain't broke, don't spend the big bucks to change it.<br> <br> Ian P.<br>
