Old 05-04-2002, 04:10 PM   #1 (permalink)
Date registered: Dec 1998
93' 300CE - Climate Control Not Blowing Hot nor Cold Air
1993 300CE:<br>
The A/C nor the heater will blow from the vents. If I push any of the fan control buttons absolutely nothing happens. Max. Fan Speed - nothing. Auto Fan Speed -nothing. Min. Fan Speed -nothing. I'm in Dallas and I need the A/C for this summer heat. <br>
<br>
What could it be and how much should I expect on the parts and labor?<br>
<br>
Thanks In Advance,<br>
Drew
Old 05-04-2002, 07:02 PM   #2 (permalink)
Did you check the fuse?
Old 05-05-2002, 11:27 AM   #3 (permalink)
Re: 93' 300CE - Climate Control Not Blowing Hot nor Cold Air
All fuses are good...<br> <br> Thanks,<br> Drew
Old 05-05-2002, 03:36 PM   #4 (permalink)
If the climate control and blower motor fuses <br> are good,then have your blower motor check.
Old 05-15-2002, 12:43 PM   #5 (permalink)
Finally fixed... I wasn't familiar with the outside fuse box with the 30amp fuse/relay. MB specialist replaced the fuse and the rest is history. MB specialist says due to weather and moisture it can corrode the fuse and cause it to blow prematurely. Checked to see if it got hot with blower on full blast, it didn't.... Im good to go. No charge.<br> <br> Thanks for your help Manny...
Old 05-15-2002, 04:11 PM   #6 (permalink)
Glad your problem is solved.
