Old 04-11-2002, 07:39 AM   #1 (permalink)
Date registered: Dec 1998
400e transmission problems
My transmission in my 400e revs 3000 to about 5000 rpms after every gear change. Recently reverse has stopped working unless I rev it up to about 6000 rpms wich is very dangerous for my engine. I had it serviced and it worked better for a little while. But now it is worse than it ever was. Is it is a vacumm problem or do i just need to rebuild the transmission.
Old 04-11-2002, 09:14 AM   #2 (permalink)
Re: 400e transmission problems
Probably not an all vacuum problem...Your transmission sounds like it needs a serious overhaul. A Vacumm problem would only make it shift rough not overrev. There is an adjustment on the transmission that might make it a little better. It is on the left side under a small black cover. Pull out the bar and turn once or twice. You might be able to make it a little better until the transmission fails.
Old 04-14-2002, 08:34 PM   #3 (permalink)
thanks edmund i will try that and see how it works, so you think i should just have it rebuilt or get a new one.
