MY newly purchased 1990 300E has no brake lights, all are out in rear. Checked bulbs, wires and fuse in fuse box. Can anyone help me locate brake light switch on this thing. <br> <br> Any help would be appreciated.<br> <br> Thanks <br> <br> Tom
It's a typical mechanical switch in the typical location. It's attached to the brake pedal arm right where it meets the shaft from the master cylinder as it pokes into the passenger compartment through the firewall. <br> <br> Should be pretty easy to get to once you get past the interior panel under the dash. Don't know about your car, but on my '89 there's plenty of room in that area.<br> <br> Later!<br> W
